Detroit True Trac
Any of you guys running a Detroit True Trac, A local driveline shop here has one for sale. No one here has ran one, I'm used to running a Eaton posi unit. If anyone out there has one please let me know how it works or if anyone has a used Eaton Posi unit for sale(non-govlok).
71 C10 2WD,472 Big Block Buick B4B Intake,800 cfm Q-Jet built by(Fred Catlin) Comp Cam 254/268@ .050 .530/542 lift 1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's Mallory fuel system Igniter Flame thrower Ignition system TH350,Hughes 3500 Converter ,3.73's Its just an old heap, but its my hot rod! |
Re: Detroit True Trac
I have one in my 68 Chevelle that I autocross/road course. They are great and make it alot easier to corner without "posi push" or to reduce power oversteer. They send only the power to the tire/tires that have traction without the posi clatter that a tight positraction can have. I have run both in performance cars and I will use a True-Trac everytime I can.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
if your taking off from dead stop in a straight line will it pull both equal at the same time. I will be drag racing this truck and just want to make sure it will launch striaght. Thanks for replying
Has more rust than truck...
Have one in my dads truck. Works great, but if in a very slippery situation (stuck in Snow/ice) it wont lock without a little e brake.
Oh yeah mine burns both tires from a stop....no problem.
I have them front and rear in My CJ-5 work great all weather.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Tru-Tracs are about the best posi I know. 4wd guys use them up front because of how well they give you "lock" when you need it and "free-spin" for steering. They work great on launching in the rear.
Thanks Guys for the input, now i have to decide between eaton and true trac
