6 lug disc brake conversion what is needed
what do i need to do to keep my 6 lug setup, i currently have drums and want to keep the truck 6 lug when i go to disc brakes. what year truck do i get the 6 lug rotors from and what year spindle do i use? thanks
#2 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 6 lug disc brake conversion what is needed
Welcome to the board! Are you adding drop spindles? Most 6-lug rotors are sold by aftermarket companies like ECE, POL, and CPP. You might want to read this FAQ. http://67-72chevytrucks.com/vboard/s...68&postcount=4 About half way thru it addresses 6-lug rotors,... but it's really good to read it all. If you still have questions please ask. You have asked a question that is talked about here alot!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-08-2011 at 11:07 AM. |
cool thanks lolife99.... yeah i got alot of questions really wanna do as much as i can on my own to my 67 project, change parts, upgrade, drop, strip.. the easy stuff, lol not only save money but i get the appreciation of the truck... and yeah i plan go get drop spindles. i wanna go pretty low with it, im currently going to run a 20/22 setup. the front will have 255/35/20 tires.. so im not sure how low i can go, wanna tuck a little tire.. im getting a hell of a deal on some used boyd rodders and wanna use them while i build up the project and drive it.. you know... eventually i'll put 22's in the front but can also just get a higher coil, and still use the spindle setup.. if that makes sense.
Be careful buying used 6-lug aftermarket wheels.
Most are made for the '99-2011 Silverado 6-lug front hubs. These hubs are smaller than the hubs on the aftermarket 67-70 6-lug rotors. Most of the time some machine work will be required. (either the wheel bore will have to be machined larger or the front hub will have to be machined smaller)
#6 | |
I have a similar kit from Early Classics Enterprises on my red '69. The McGaughy's kit will work great also!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-08-2011 at 11:17 AM. |
yeah well the wheels im getting are off a 2001 style chevy, if i have to machine the wheel hubs i got a guy in your truck club that can machine them for me at $40 each.. so i already thought about that..
#8 | |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 02-08-2011 at 01:32 PM. |
#9 | |
Thanks.
If you are doing this yourself these threads might help in particuliar removing the bushings by burning them out.
http://67-72chevytrucks.com/vboard/s...d.php?t=441326 http://67-72chevytrucks.com/vboard/s...d.php?t=439858
1990 chevy 4x4 with a 1940 IHC body |
#11 | |
The 67-72 trucks have a different style cross-shaft, a-arm,... and steel bushings.
yeah im aware of the spindles i have to buy to go with the brake kit... not sure if im going to do stock spindles with the 4" hotchkis coil or drop spindles with a 2 or 3 inch coil... according to hotchkis seller the 4" coil will not cause any camber wear
#13 |
I wonder how they keep a 4" lowering coil in the pockets. 3" have been known fall out when the "A" arms are extended all the way. Also a spring can not correct for the camber. That can only be done with shims, or tubular "A" arms designed to do so. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#14 | |
I just recently went and did this on my 70, came across a great setup that bolts directly up after removing your old spindles. http://www.classicheartbeat.com/67-7...suspension.htm http://www.classicheartbeat.com/cata...sion%20Kit.htm
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#15 |
This caught my attention because I had in the past cut my coils down to give me a 4" drop and my coils did easily shift around in the pockets and fall out.
#16 |
Ya, I love it when a company make claims that are not possible to sell their wares...
#17 |
![]() Join Date: Oct 2007
You are also going to have to add a Master Cylinder and proportioning valve for a disc/drum setup.
#18 |
careful i just did mine on a 69 and now wheels are pushed out 7/8" on each side i called cpp and they said that was normal unless you go with the offset correction set
#19 | |
#20 |
so much stuff to take into consideration.. thanks again for the input... glad to know i can ask for help for the site..
#21 |
its all about the +6 inches
I don't have any photos, and I can never seem to explain it very well, however, there is a very easy and DIRT CHEAP way to keep the too short springs from falling out. All you need to do is remove the rubber bumper from the upper control arm, then place a long bolt in it, head side down, and then use a nut on the bottom side of the upper A arm, and on the top side where the bolt comes through. I can't remember how long, nor even the diameter needed for this, but it is real easy to figure out if you have a wheel removed.
To figure the adjustment, jack up the front end (by the crossmember, not the a arm) untill the spring gets a little loose. Lower the jack till the spring doesn't rattle at all (grab it and try to turn it and wiggle it). Adjust the bolt to where it makes contact with the crossmember/top side of spring pocket. Rinse and repeat for the other side and you are done. Maybe some black spray paint to make the stuff disapear. As for the 6 lug rotors... look at the price of the rotors, and compair it to the price of a 5 lug for the same year suspention. Remember that you do need to replace rotors from time to time (more important on a driver than a garage queen). Also keep in mind, that one or possibly 2 companies make this part, for a rather small market. If (i say when) they stop making them, then you will be forced to do something else, and if you have big rims and tires, that could be stupid expensive. Just another view on the 6 lug conversons. I say 5 lug is cheaper in the long run |
#22 |
so i found a guy in dallas with the front spindles stock and brakes and rotors complete 5 lug and the rear end from the same truck complete all for $150 bucks... is that about right?
i think it came out of a 71 i think |
#23 | |
Just make sure the rotor "width" is 1-1/4".
#24 |
So lolife if I keep the 5 lug set he is selling all this bolts up? Is 150 a deal ?
Posted via Mobile Device |
#25 | |
Just the spindle assembly and the rearend? A-arms? Complete steeing linkage? Crossmember?
