Old 02-08-2011, 12:02 PM   #1
674x4ton
will a 3/4 ton 67 chevy truck front wrap--fit on a 1967 chevy C-50 cab?
Thinking about buying a 1967 chevy C-50 truck to use the rust free cab .My question is will my 67 chevy 3/4 ton front wrap fit on the cab?
674x4ton is offline   Reply With Quote
Old 02-08-2011, 12:20 PM   #2
jrdv
jrdv's Avatar
Re: will a 3/4 ton 67 chevy truck front wrap--fit on a 1967 chevy C-50 cab?
Can't help, but I have always wondered about this too.
jrdv is offline   Reply With Quote
Old 02-08-2011, 12:36 PM   #3
maynardtruckin
maynardtruckin's Avatar
It is the same cab and the front wrap will inter change!
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 02-08-2011, 12:43 PM   #4
674x4ton
Thanks--i will try to buy the old C-50 truck
Old 02-08-2011, 12:47 PM   #5
Livrat
Member #1049
Livrat's Avatar
It will physically sit on the cowl the same, but only two bolts will line up as the firewall, cowl, lower floor and front cab supports are completley different.
Livrat is offline   Reply With Quote
Old 02-08-2011, 01:21 PM   #6
674x4ton
It will take some work ,but can be done? Want to use this cab,for the small back window and having the clearance lights on the roof.This will be a project to build a C-30 1-ton 4x4 longbed stepside truck.
Old 02-08-2011, 03:01 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you don't mind cutting off the lower front third of the cab and welding on from a donor, then it'll work.
For anyone else who doesn't want to do this much cutting and welding, then the simple answer is no
