Old 02-08-2011, 01:32 PM   #1
osaltyone
osaltyone's Avatar
c10 & c20
I have been looking for a 60-63 C10, but found a C20 with the BBW I want in my price range. What is the difference between the 2? just 1/2ton 3/4ton? Is the frame the same? I was thinking of a dropmember in it, so just wanted to be sure before I bought it.
osaltyone is offline   Reply With Quote
Old 02-08-2011, 01:40 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: c10 & c20
The cab mounts are different also.
LT1 Burb is offline   Reply With Quote
Old 02-08-2011, 01:41 PM   #3
lakeroadster
Re: c10 & c20
8 lug wheels vs 6 lug wheels, different rear end, different springs
lakeroadster is offline   Reply With Quote
Old 02-08-2011, 05:41 PM   #4
maynardtruckin
maynardtruckin's Avatar
Re: c10 & c20
Basically the standard 1/2 ton to 3/4 ton differences thicker cab mounts heavy duty suspension 8 lug wheels and brakes, and axles. It can be changed to a c10 easily.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 02-08-2011, 06:52 PM   #5
jimmydean
jimmydean's Avatar
Re: c10 & c20
Yup, I am in the process of changing my C20 to 5 lug 1/2 ton. I got the C20 because it had the motor/trans I wanted and was in better shape than the C10's I looked at. I was swapping to 5 lug either way, so the body mount change was the only additional mod I added to the project list.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-08-2011, 07:10 PM   #6
oem4me
Re: c10 & c20
The half tons I've owned (all stock '63-'66) have been a breeze to drive even without power steering. My '62 three quarter ton is a real son-of-a-gun in tight spots and for parking. I assume it's the heavier suspension that makes a BIG difference at the wheel.
Old 02-09-2011, 12:36 AM   #7
osaltyone
osaltyone's Avatar
Re: c10 & c20
Thanks for all the responses. I will go check out the truck this weekend a bit more and maybe pull the trigger if the wife doesn't flip...
