Registered Cruiser
Leaf Spring Perches/ Location
Had to remove the perches off my 12 bolt, they were hacked off and welded back on under the axle as a "rigged" flip kit, prior owner... Anyway, does anyone know the distance between the two leaf spring perches? Center hole to center hole? Need to weld new ones on and cant seem to find any info on the measurements...
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
Hollister Road Co.
Re: Leaf Spring Perches/ Location
You'd be better off setting the rear and perches under the springs, snug the u bolts up, set the side to side, set the pinion angle then weld them in place.
Registered Cruiser
Thanks dwcsr, however, I should have explained a little more... I'm actually adding PB 4 link rear, so using your method wouldn't work for me, sorry bout that, but thanks foe the reply! Anyone know where I can find The measurement or know of an alternate solution?
#4 | |
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Registered Cruiser
That makes a heck of a lot of sense
