Old 02-08-2011, 08:22 PM   #1
Mike J
vw guy & now c-10 guy
Mike J's Avatar
250 6 cyl. monojet choke setup- can somebody show me some pics?
Ive be running my truck with a spring holding the throttle plate- I have a manual choke cable but I dont have the linkage for the carb- can I get some pics to see what I need to find and/or make? thanks guys!!!
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-08-2011, 11:21 PM   #2
Mike J
Mike J's Avatar
Re: 250 6 cyl. monojet choke setup- can somebody show me some pics?
anybody? just love to see some pics of the parts i'm missing
'68 long fleet
My Build Thread
Old 02-08-2011, 11:28 PM   #3
Luvlegs
Luvlegs's Avatar
here's mine ('72 if it makes a difference) (pre rebuild)
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 02-08-2011, 11:52 PM   #4
Mike J
Mike J's Avatar
mine doesn't have any of the stuff on the front of yours- no choke pull-off and no choke thermostat or rod. but I have a brand new choke cable if I can figure out how to mount it and make it operate. thanks for the pic! I'm open to either way, I just want it to work!
'68 long fleet
My Build Thread
Old 02-09-2011, 12:00 AM   #5
Luvlegs
Luvlegs's Avatar
aaahhhh they are over rated! hahahahhaah I still have to stay with mine for about 2 minutes before I can leave it to settle out on it's own. I recently rebuilt the carb but can't find the pics. If I do, I'll add some more pics.
found it:
http://67-72chevytrucks.com/vboard/s...d.php?t=439692
1972 C10 L6 3OTT
Old 02-09-2011, 10:44 AM   #6
Wrenchbender Ret
There were several different choke configurations used through the early years of these carbs. Most of them didn't work right from day one. Often the carb or manifold has been changed & do not match. Often parts are missing off the carb. The best one to use is the electric choke model from the early 80's. It is self contained. Or a manual choke model is good. It is hard to convert to a cable control.
Wrenchbender Ret is offline   Reply With Quote
Old 02-09-2011, 11:11 AM   #7
68gmsee
Active Member
68gmsee's Avatar
I have several pics and can get you some more (weather allowing) but I need to know what you need.
When you say you have a "manual choke and don't have the linkage to the carb" do you need to know how the choke cable attaches to the carb or the throttle linkage to the carb?
68gmsee is offline   Reply With Quote
Old 02-09-2011, 11:38 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Okay, I read this post. Not all vehicles had pull offs. Back in those days you had to learn how work it manually. Basically you had to be one with your truck.
Here's some pics of mine:
Well, I thought I was going to be able to send pics, but it's not letting me upload them. I'll try to figure out what's wrong and post pics later.
Old 02-09-2011, 12:44 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Let me know if you need some more pics.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 02-09-2011, 03:11 PM   #10
Mike J
Mike J's Avatar
thanks guys! that should help me out a lot
'68 long fleet
My Build Thread
Old 02-09-2011, 03:26 PM   #11
stepside fan
a few pics from my 68......................
stepside fan is offline   Reply With Quote
Old 02-09-2011, 07:11 PM   #12
Mike J
Mike J's Avatar
ok, sorry to make this thread so long... I'm sure this is really simple to lots of you, but this is my first chevy- up til I started building this 68, it was 20 straight years of VWs for me
Here's some pics, not the best, but pics nonetheless:
'68 long fleet
My Build Thread
Old 02-10-2011, 11:57 AM   #13
292cclb
that is a work of art stepside fan. very nice!
292cclb is offline   Reply With Quote
Old 02-10-2011, 06:06 PM   #14
stepside fan
Thankyou..............
