Changing Trannys
Well i hope someone can help me. i'm going to remove 4 speed trans and replace with a 200r. i know the factory auto trans has a lower hump where can i get one. i have a 65 swb any help would be great my dog has a kink in his neck so he needs a lower hump.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Changing Trannys
You're going to have to find a used one. I believe you will also have to change the part to the front of the removeable trans cover. It is spot welded to the firewall. This piece is different for the short and tall trans covers.
You could take a look in the classifieds here on the forum. You might find someone parting out a truck or just a cab. Usually guys are going the other way, short to tall, so someone could have leftover parts from their conversion. However to be able to post a WTB, you must be a supporting member.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-09-2011 at 02:09 AM. |
