Old 03-14-2003, 11:54 PM   #1
charlieo
lifting a 4x4
I heard that on the older chevys trucks ( 67-72) when you lift it , it's best to lift it through the springs and not block it. Do the blocks make it too unstable ? How much lift can I get by using spring lift and do you guys suggest the soft ride springs ? Thanx
charlieo is offline   Reply With Quote
Old 03-15-2003, 12:04 AM   #2
Pont
I need another Barley Pop
Pont's Avatar
I highly recommend the Softride springs. I'm running 8" Skyjacker softride springs on my truck. As far as blocks go, I don't think you are any more likely to have problems with the 67-72 than you would with any other rear. The taller the rear block, the more unstable it will become. Skyjacker and Superlift make up to a 12" lift for the 69-72 trucks. Any higher than that and you will have to have custom springs made. If your lifting a 67 or 68, you will have to have rear springs custom made regardless. Nobody makes rear lift springs for these 2 years. Hope this helps.........
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 03-15-2003, 12:13 AM   #3
charlieo
69 swb 4x4
Yeah it does help & I appreciate it . Thanx ! Just read your reply to the cross over steering . Great !
Old 03-15-2003, 03:14 PM   #4
twistedmetal
Take it to the limit
twistedmetal's Avatar
There are spring rebuilding shops al over the place,and personally i've had great luck with them over arching springs and getting them sitting even.have also dearched them there for lowriders,i probably as a rule wouldn't go any more than + or- 3 inches this way though.hope this helps.
Happiness is driving over a Honda
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
Old 03-16-2003, 01:17 AM   #5
smithjp1
smithjp1's Avatar
I had all my springs re-arched with an add a leaf, that gave me a total of 3 inches, all for $225
1968 4x4 swb
smithjp1 is offline   Reply With Quote
Old 03-16-2003, 01:21 AM   #6
twistedmetal
smithjp1 ,,you wouldn't go any more than 3 " either??I kinda drew my own standards at 3"
"If Fall Guy only knew how many trucks i wrecked,He'd be proud"
