Old 02-09-2011, 01:38 AM   #1
jrdv
jrdv's Avatar
New Tires and Rims!
I've got new treads. I had to buy some 16X10 rims in order to fit the 33/12.50/16 Interco Trxus tires. The rims are Rock Crawlers.
I wonder if I got the wrong back spacing. They stick out too dang far.......either that or I'm too dang old!
What do you think?
John
jrdv is offline   Reply With Quote
Old 02-09-2011, 01:41 AM   #2
71veronica
71veronica's Avatar
Re: New Tires and Rims!
I like it
71veronica is offline   Reply With Quote
Old 02-09-2011, 01:49 AM   #3
jrdv
jrdv's Avatar
Sorry, I forgot, the backspacing is 4 inches. Only about 1/2 inch of my rear drums is covered. I didn't take a pic of that.
Old 02-09-2011, 03:04 PM   #4
SeventyOne
I think the BS looks spot on.
SeventyOne is offline   Reply With Quote
Old 02-09-2011, 03:18 PM   #5
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Looks great John! The sticking out part looks par for the course when you sign up for 10” wide wheels. I prefer no more than 8" wide for that reason. The off-set looks right.
DirtyLarry is offline   Reply With Quote
Old 02-09-2011, 06:27 PM   #6
Redcap
Looks just fine to me.
Redcap is offline   Reply With Quote
Old 02-09-2011, 06:49 PM   #7
jakeblues652
jakeblues652's Avatar
lookin gooood
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 02-09-2011, 06:57 PM   #8
elks
Wow that one tire took way too much weight to balance? Whats the deal. I have ran big mud tires for years and never had one take that much to balance it. I think they look great and the back spacing looks fine. Only problem is it will throw mud and rocks up a lot. It your worried about your paint you might want to move em in a bit.
On that tire with all the weight try rotating the the tire on the rim a 180 degrees and reblancing sometimes that will lessen the amount of weight. If not I would contact you supplier and see about a swap...
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 02-09-2011, 07:15 PM   #9
DirtyLarry
DirtyLarry's Avatar
I didn't notice that weight! WOW....You're right! That looks a bit extreme. Might want to look into that John....maybe even trade them for 8" wheels
Old 02-10-2011, 01:45 AM   #10
jrdv
jrdv's Avatar
Thanks guys.
I am going to take the "over weighted" tire and rim back in and get the tire shop to give it another try!
Larry,
I'm thinking that is what I should of ordered in the first place. I was worried about the 12.50 wearing too fast in the middle?
I will post some more pictures after I get done with the motor swap....aka "paint and other things that I didn't plan on doing"!
John
Old 02-11-2011, 12:18 PM   #11
jrdv
jrdv's Avatar
Here's a pic of the brake drums. Seems a little extreme!
Old 02-11-2011, 12:45 PM   #12
sdailey
The Few, The Proud
sdailey's Avatar
John,
The backspacing does look a little odd when looking at the rear drum like that, but it looks normal on the body side though. Hmmmm...... Just for more confusion here's a picture of the rear drum on my '69 K10 with a 12" wheel. I can't remember if the offset is 4" or 4.5".
Here's a picture showing how deep they are. How deep is the lip on your wheels?
Shannon
sdailey is offline   Reply With Quote
Old 02-11-2011, 02:32 PM   #13
Altec
Getcha Pull
Altec's Avatar
Most of the guys I see running drums on 3/4 and 1-ton axles stick out like that. It is fine.
I gotta ask about them weights too. I'd want my money back if I had to run that many weights. Have you tried breaking the bead, and turning the tire 180* on the wheel? I'm told that can help. Considering some scary stories I've heard about those tires already, that just concerns me.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 02-11-2011, 02:39 PM   #14
jrdv
jrdv's Avatar
I haven't made it back to town to get the tire rebalanced. The other 3 just have one weight on them.
I never payed attention to how far the drums stuck out until now! I am going to run with it anyway!
john
Old 02-11-2011, 02:40 PM   #15
jrdv
jrdv's Avatar
Sdailey "Here's a picture showing how deep they are. How deep is the lip on your wheels?
Thanks for the reference pics.
I will have to measure how deep they are.
John
Old 02-11-2011, 04:54 PM   #16
jakeblues652
make sure you keep them up to pressure. i know alot of buds with those rims (some 16" some 16.5") and they LOVE to pop off the bed when they aren't right up to pressure.
Old 02-11-2011, 05:01 PM   #17
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Looks nice! Yep, that truck is way to clean to not fix that firewall by the way...
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 02-11-2011, 05:04 PM   #18
sdailey
The Few, The Proud
sdailey's Avatar
John
Disregard my post I just realized that your truck is a 3/4 ton model. I was just assuming that it was a K10.
Nice looking wheel/tire combo though. The truck looks good too.
Shannon
Old 02-12-2011, 09:09 AM   #19
14-bolt drums always hang in like that. Those look badass. I've never had problems with tires popping of of 10" wheels. Can't understand why anyone would think that. I've run then so low I'm embarrassed to admit. Never threw a tire. The balancing is downright unprofessional. Sorry tire guy,you may get away with first time mount ing and balancing most all the time,but when you get one that takes all that you know you need to dismount and rotate to get the heavy spot of both the tire and wheel way from each other. Not rocket science,just tire mounting 101.
Old 09-20-2011, 02:15 PM   #20
86ktwenty
86ktwenty's Avatar
Heres mine.
1998 Chevy Z71
1989 Chevy S-10
1978 Chevy K-10
1983 GMC K3500
1974 Chevy Cheyenne Super 20 4x4
86ktwenty is offline   Reply With Quote
Old 09-23-2011, 10:59 PM   #21
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Nice they look great I think. Ya most of the 3/4 tons and up look like that in the back from what I have seen.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-24-2011, 02:34 AM   #22
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
We should start a "Let's see some pics of your 3/4 ton brake drums!" It's a little dark, but you can see them if you squint.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 09-24-2011, 10:03 PM   #23
86ktwenty
86ktwenty's Avatar
3/4 ton and up!
1998 Chevy Z71
1989 Chevy S-10
1978 Chevy K-10
1983 GMC K3500
Old 09-24-2011, 11:55 PM   #24
rayfinseats
Have them turn that tire 180 degrees on the rim and it will balance out better. There is about 10 pounds of weight on there.
rayfinseats is offline   Reply With Quote
