Old 02-09-2011, 06:28 AM   #1
steelscout
Words under my name
steelscout's Avatar
vacuum test issues
I purchased a Vacuum test (first picture) and I hooked to the carb at the tube sticking from the carb with the screw in it (second picture), at idle it registered nothing, at aprox. 2k rpms it registered around 17-18. I am not confident that this is a good place to test vacuum. If this is fine then cool, if not where should I plug in? any advise would be great.
Thanks in advance
69 Chevy CST/10 "Project: Bloody Knuckles" my slow going project.
2010 VW Golf, daily driver
Wrench Rookie
steelscout is offline   Reply With Quote
Old 02-09-2011, 06:36 AM   #2
JimKshortstep4x4
Re: vacuum test issues
The location that you hooked your gauge to is "ported" vacuum and it will be more helpful to check manifold vacuum. (Ported vacuum is above the throttle plates and manifold vacuum is below the throttle plates).
If you have a vacuum line from the transmission you can hook up to the location and get manifold vacuum.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-09-2011, 08:28 AM   #3
steelscout
Words under my name
steelscout's Avatar
Thank you Jim
Wrench Rookie
