Old 02-09-2011, 11:04 AM   #1
sixtyeightchevykid
sixtyeightchevykid's Avatar
inline exhaust setups(yes another one)
hello everyone, i currently have a stock 250 with the stock manifold and a single pipe going into a thrush glasspack that dumps just behind the cab. i took it to a local shop to have a newdown pipe put on and just a cheap muffler so i could be somewhat legal and the old down pipe was paper thin and had holes. so i have been driving with a not so good sounding exhaust for awhile and im ready for a change. i thought of cutting the glasspack off and putting a flowmaster or a magnaflow in and running a pipe from there to infront of the drivers side rear tire. but im not sure if that would change the sound that much. or for the better. so i guess what im asking is can you all that have inlines post up how your exhaust is set up what muffler and any experiance you have about sound, and how it sounds. im looking and hoping for a more deep tone and less rasp/pissed off bee sound.
sixtyeightchevykid is offline   Reply With Quote
Old 02-09-2011, 12:34 PM   #2
Sonicman
Sonicman's Avatar
Re: inline exhaust setups(yes another one)
I have a 250 with Clifford performance intake with a 4 barrel eddlebrock carb and Clifford dual shorty headers. The pipes rum from the dual headers and Y together then I have a single in single out 40 series flowmaster in the stock location and the tail pipe is stock just behind the driver tire. When idling it sounds like a V8 put not so much when running down the road. But I think it sounds good. I'll see if if I can get some exhaust pics up tonight. I do have pics of my engine in my album.
Sonicman is offline   Reply With Quote
Old 02-10-2011, 10:16 AM   #3
sixtyeightchevykid
thanks sonicman it looks like you are the only one that has something done with your exhaust
Old 02-10-2011, 11:27 AM   #4
geezer#99
geezer#99's Avatar
Me too!!
Langdon's headers into 2 1/4" pipes back to dynamax turbos above the trailing arms and then 2" tailpipes. Sounds like a v8 too.
Run your exhaust all the way out the back. It's quieter!!
Old 02-10-2011, 11:28 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I don't think you are going to be happy with it unless you run it all the way to the back. It is amazing how much difference it makes. All of my exhausts are stock type even the two sixes... all the way back.
Geezer#99, posted at the same time. All great minds think alike...
LockDoc
Leon
Old 02-10-2011, 11:56 AM   #6
slomotion
Old Duffer
slomotion's Avatar
Running the stock exhaust I agree with Leon. Your best bet is stock all the way back.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 02-10-2011, 11:05 PM   #7
sixtyeightchevykid
ok so better sound if the tail pipe in the stock location or just out the back?
if you have duals are you running one pipe on the drivers side and the other on the passenger side? or just running both allong the drivers side?
any one running flowmasters?
Old 02-10-2011, 11:17 PM   #8
geezer#99
geezer#99's Avatar
On mine the passenger side goes under the pan in front of the sump. Run them out the back and it's quieter.
Old 02-10-2011, 11:32 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Refer to page 9 and 10 for the install of my stock setup in my '69.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-11-2011, 12:00 AM   #10
BadaSs_Cal
BadaSs_Cal's Avatar
I have a flowmaster , dumps under the bed.. sounds pretty good driving.. I like the loud sound tho.. especially with the 4 speed.. sounds like I have a V-7...lol
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 02-11-2011, 09:16 AM   #11
slomotion
Old Duffer
slomotion's Avatar
In your first post you mentioned you had a stock exhaust manifold, so I just assumed you were going to run a single pipe. As you've read in the last several posts there's several ways to go........
If you're going to run headers, here's one more way: 2 1/4" off the headers into a late model muffler mounted backwards (it's a flow through) with a 3" down pipe behind the cab. Sounds good, but not too loud
and WC T5 trans.
'81 G10 Shorty Van
Old 02-11-2011, 10:00 AM   #12
sixtyeightchevykid
im torn between the stock manifold and headers so im open to ideas for both. for some reason i dont want to have exhaust running down the passengers side if i did duals.
Old 02-11-2011, 11:34 AM   #13
70ChevyC10Kermit
70ChevyC10Kermit's Avatar
I have a 250 ci with Clifford Performance stuff...cam, intake (Edelbrock 500 cfm 4 bbl carb), shorty headers, x-pipe. I've got the dual shorty headers bolted up to 2 1/4" pipes, welded in the X-Pipe, then through Magnaflow 3 chambers, then straight out the back of the truck. I think it sounds good. Definitely sounds like an 8 cylinder at idle and low rpm.
"Kermit"--1970 C/10 Shortbed Stepside
Original L-6 250 ci, bored .030 over
Clifford Performance 270 cam, intake, shorty headers
Edelbrock Performer 500 cfm 4 bbl carb
Cherry Bomb Glasspacks, ECE 4/6" Drop/Disc Kit
Hurst Driveline Conversions Tremec TKO 5-speed
70ChevyC10Kermit is offline   Reply With Quote
Old 02-11-2011, 01:29 PM   #14
bosco200
bosco200's Avatar
Just cut the exhaust off
bosco200 is offline   Reply With Quote
Old 02-11-2011, 04:03 PM   #15
Mike J
vw guy & now c-10 guy
Mike J's Avatar
ha ha. that's the way mine is right now. Has about 2 feet of downpipe from the manifold and that's it.
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-11-2011, 05:05 PM   #16
bosco200
bosco200's Avatar
Mine to I cut it off right at the muffler
Old 02-11-2011, 10:39 PM   #17
sixtyeightchevykid
i have some random peices of exhaust pipe, what i think i will do is see if putting a pipe from the muffler back to stock location or maybe some other spot trying to find the best set up for the best sound with the glasspack.
