Old 02-09-2011, 11:17 AM   #1
674x4ton
Needing pictures of 67-68 chevy C-50 cab with out the front wrap
Needing a picture of a 67-68 C-50 cab with out the front wrap.Wanting see what the firewall look like,and what needed to weld,so i can put a 1/2 ton front end onto the C-50 cab.
674x4ton is offline   Reply With Quote
Old 02-09-2011, 06:12 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Needing pictures of 67-68 chevy C-50 cab with out the front wrap
I don't have a pic to help with but sounds interesting.I do hope you realize that the doors are also different so you may have to swap out front cab pillars also.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-09-2011, 06:45 PM   #3
674x4ton
Thanks,sound like it will be to much work--to make it work.
Old 02-10-2011, 12:35 AM   #4
Livrat
Member #1049
Livrat's Avatar
here you go.. as you can see the firewall is much deeper, the outer lower firewall is recessed rearward to clear the large tires, the steering column comes out of the firewall lower, the brake booster is lower, the front cab supports also sweep back instead of straight out.. and all of the lower fender mounts are different than a standard cab
Livrat is offline   Reply With Quote
Old 02-10-2011, 12:38 AM   #5
67chevy1series
67chevy1series's Avatar
cut the fron of a 67 68 c10 and put it on a 67 68 c50 cab and you should be good
67chevy1series is offline   Reply With Quote
Old 02-10-2011, 08:30 AM   #6
BlazinC5
BlazinC5's Avatar
Hmmmm, I never really gave it much thought. I always figured the cabs were pretty much the same. I woulda thought with all the years I crawled under my brothers C-50 wheat truck i woulda noticed. Learned sumthin new today.
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
Old 02-11-2011, 10:18 AM   #7
674x4ton
Thanks-Livrat for the picture of the C-50 i can see what i'am up against. I don't think i can do that good of a job welding and cuting. I guess i will go with plan 2 a 55 chevy 2-ton cab on a 70 chevy 4x4 truck frame.Should look mean and tought.
