Old 02-09-2011, 02:38 PM   #1
Silence86
Silence86's Avatar
what fuel pump
just wandering what fuel pump you guys are using? i know there needs to be 58-60 psi at the fuel rail. but is all i need is a regulator, pump and lines? trying to get a parts list for after bootcamp. any other things needed to do this swap? i know mounts, tranny xmember, harness and all that but just trying to go over this seeing i leave sunday, thanks in advanced guys
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622
Silence86 is offline   Reply With Quote
Old 02-09-2011, 03:11 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: what fuel pump
are you using a truck style or the returnless corvette style fuel system? If your using the truck style, you need supply and return lines, and the pump. The reg is built into the rail on that system. If your using the 'vette style, then you need the reg/filter combo, supply line, and the pump.
I'm just using a Walboro/Jegs brand 255lph inline pump, with a matching high flow filter on my truck (with the truck style fuel system)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-09-2011, 04:03 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: what fuel pump
I used a Pierburg pump, I got mine from Turnkey motors, rather high, but I claim ignorance on that. You will need LS mounting plates from Dirty Dingo, they are adjustable front to back. Also you will need to think about AC, if you want it or not. If you do, you will need a high mount bracket and a Sanden compressor. Kwick Performance is where to get the bracket.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-09-2011, 04:33 PM   #4
Silence86
Silence86's Avatar
Re: what fuel pump
i wont be running ac so no bracket needed for that. the mounts are on the list. is there somewhere to get a tranny x member or is it easier to just make one? as far as fuel pump, i want to run just a basic setup. i know i can use a sending unit from a 91 burb or blazer. i know 85 burb had a holley pump but couldnt find a part number in his thread( just skimmed). even tho he is using a carb would you be able to use that setup for a injected system? sorry for all the q guys haha
Old 02-09-2011, 04:46 PM   #5
Silence86
Silence86's Avatar
Re: what fuel pump
also as far as gauges? what gauges are best to use? this is all going in a 86 chevy swb im saving all the wiring till after i get the motor and trans seeing there is different applications. anything else im missing?
Old 02-10-2011, 10:02 AM   #6
Shon
Re: what fuel pump
I am running a "E2000" fuel pump from ebay, like $40 shipped, stock 6.0 with headers and it does fine. I use the 'vette reg/filter post pump but have a filter pre-pump too.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 02-10-2011, 10:56 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: what fuel pump
there is also no "best gauges". Speedo will need to be electronic instead of cable driven if you are using a 4l80 or 4l60 trans. Stock fuel gauge and temp gauges can be made to work. Trans xmemeber can usually be modified to fit the new tranny, usually by elongating a couple holes and shifting its location.
Old 02-10-2011, 11:01 AM   #8
Shon
Re: what fuel pump
Why? Granted it depends on the look he wants but I am running stock Speedo with my 4l80e, using the CableX box (which I sale for 'cheap'). But if he wants to change all his gauges then buying a electronic speedo is just as easy.
