Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 02-09-2011, 04:07 PM   #1
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
09 rear end swap
I have a line on a complete 3:73 rear end assembly out of an 08 sierra that I would like to swap into my 09 crew that has 3:32 gears. This unit is LOW mileage, and the rear-end is CHEAP! I would be switching everything from brake drum to brake drum.
I need to ask the obvious questions here:
1. will it fit correctly
2. will it create problems with ABS, Traction control, etc.
3. can the computer be re-flashed for a different ratio cheaply and/or easily
4. what other problems have I not thought about that this swap might cause (other that warranty issues)
Will this be a "plug and play" swap? I googled and came up with several threads on boards that are not nearly as friendly as ours, and that left me with more questions than before.
I have wanted to make this swap since I got the truck, but gear swaps are very expensive on these trucks.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 03-02-2011, 02:58 AM   #2
Jerry Jones
Happy Camper
Jerry Jones's Avatar
Re: 09 rear end swap
Long awaited bump for you!
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 03-02-2011, 11:28 PM   #3
Bus Ted Knuckle
Son of a gun
Thanks Jerry! I already let the rear end go though.
I just don't know much about this latest generation of trucks.
BEATERS ARE NEATER
