Old 02-09-2011, 04:25 PM   #1
Surfdaddy
Surfdaddy's Avatar
Smoothie wheels
Has anyone bought wheels from Wheelsmith in Corona. I was looking in DRIVE mag and there seem to be a few wheel makers out there. I need to replace the split rim wheels on my 61 3/4 ton and want to run the stock hubcaps. I thought that I could use smoothie type wheel that would look close to stock. I need to replace them before I drive around too much and the tires fall off. I know this has been done about a thousand times but it's a first for me. After reading the thread on Stocton Wheel I thought I should find a place closer.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 02-09-2011, 06:01 PM   #2
onequickchevy
onequickchevy's Avatar
Re: Smoothie wheels
My wheels came from Vision Wheels. They are Chevrolet Rallye's and they were absolutely cheap. They balance up perfect and came fully dressed with center cap and trim ring for about 300 a set. On a side note, holy cow that's a ton of wheel weights on the tire in your picture!!
Slowly but surely getting it done.
onequickchevy is offline   Reply With Quote
Old 02-09-2011, 06:22 PM   #3
Surfdaddy
Surfdaddy's Avatar
Re: Smoothie wheels
The wheel weights are because it's a split rim wheel. I don't know if they make 8 lug ralley's, since my truck is 3/4 ton. I would really like to rechrome the hub caps and use them.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-09-2011, 06:41 PM   #4
Surfdaddy
Surfdaddy's Avatar
Re: Smoothie wheels
What can I do to replace the spilit rim wheels any suggestions? . Other than mag style wheels what options do I have?
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-09-2011, 08:03 PM   #5
onequickchevy
Re: Smoothie wheels
Bummer on the 8 lug, mine are 5 or 6 lug config only. How about a set of late model chevy or gmc? I'm with you though I like a steel wheel. You could have the center cut out put in a new wheel of your choice. I think stockton does this? Maybe someone else will chime in......
Old 02-10-2011, 12:30 AM   #6
Captainfab
60-66 Nut
Re: Smoothie wheels
Are those split rims 16"? If so and if you want to be able to run those hub caps, you might have to have someone weld those centers into a 16" hoop. Do a search in the 'Projects and Builds' section for Aerotruck's build thread. He welded his wheel centers in newer 17" hoops himself. Of course that is something not everyone is capable of doing, but you can get an idea of what can be done. Sorry I can't help you with where to look for wheels. I would imagine someone will have a good place for you to check out.
Those hub caps would look cool sitting inside a little wider and newer rim.
Old 02-10-2011, 08:39 AM   #7
KruizerKing91
KruizerKing91's Avatar
Re: Smoothie wheels
later model 8 lug steel wheels that still have the outer center cap nipples should work. try the junk yard and just make sure not to grab a 16.5 wheel. and it doesnt necessarily have to be off of a gm. early dodge and for also shared the same 8 lug pattern
KruizerKing91 is offline   Reply With Quote
Old 02-10-2011, 10:29 AM   #8
7T2
Active Member
7T2's Avatar
Re: Smoothie wheels
That won't work with those hubcaps. They use clips on the wheel to hold them on. I have been looking for some good stock wheels to run the same hubcap on, and they are scarce.
Wheel Vintiques just started producing wheels with the correct clips, but so far they only come in 5 on 4.5 and 5 on 4.75 bolt patterns. I am waiting for them to offer a 5 on 5 bolt pattern. 6 or 8 lug are probably even further off, if at all.
I can't even find old used wheels that work, because they are usually tapered in the back and don't fit over modern discs and drums.
This is what I am currently running, but it was a lot of fabrication work to do it, and I would still like to run stock wheels sometimes:
Here is the "how to" thread I did:
http://67-72chevytrucks.com/vboard/s...d.php?t=244882
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 02-10-2011, 11:30 AM   #9
Surfdaddy
Surfdaddy's Avatar
Re: Smoothie wheels
These wheels are 15". I called Smith wheel in Corona Ca. and they said the smoothie's are only offered in 5 or 6 lug. The only option they said was to go with there OEM wheel. I don't know if you can put a 16" rim on a 15" center but I'll call them to see if they can. The truck has 16.5's on the back and I had those on a 69 Ford truck years ago. The tire size is very limited and won't lend it's self to how I want to set up the truck. Bummer that this is harder than I thought I realy don't want to drive around with these cracked and scarry tires.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 02-10-2011, 01:42 PM   #10
Surfdaddy
Surfdaddy's Avatar
Re: Smoothie wheels
That was a cool way of getting the hub caps on those wheels. Looks great. However since I've got a 3/4 ton with 8 lug I couldn't see that they offer a wheel for me. I called Wheel Smith again and asked if they could take the centers off my stock wheels and put them on 16 or 15" rims. He said to meassure the center and he might be able to do 16" I may go with either (15 or 16) I'l just have to mess with tire size. I'm not going to put 8 or 10 ply tires on this since It will never have anything heavy in it again. Going to be as close to a custom as I can make it without cutting changing the basic layout of the truck.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
