Old 02-09-2011, 05:09 PM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Mounting 4L80E question
Hi,
I'm installing a 4L80E tranny behind my LQ9 6.0L in a '87 SWB 2WD and I'm searching for just the basic steps of how to bolt up the tranny to the motor.
Are there any threads outlining this with pics that anyone knows about? Any sites that might list out the parts I need to do this as well (seals and gaskets?)
I've done some searching and the best I've found todate is this one:
http://www.ls1truck.com/forums/front...rans-swap.html
Any leads are appreciated!! Thanks!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 02-12-2011, 08:43 PM   #2
Gordonr1973
Home Built '87
Re: Mounting 4L80E question
bump
Gordon
Old 02-12-2011, 09:30 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
You will need the crank spacer, 4l80e flexplate, flexplate bolts and bell housing bolts. Make sure the torque converter is seated before you try bolting the trans up. Should not need any gaskets or seals unless you want to replace your torque converter seal. Hope this helps.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-13-2011, 12:13 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
did the trans come WITH the lq9? if so, I dont think you have to do anything
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-13-2011, 12:35 AM   #5
Gordonr1973
Home Built '87
No the transmission is from a different truck. The Lq9 is from a 2004 Chev silverado SS, the 4L80E is from a 2wd 2003 Chev 3500 flat deck.
I'm just having a mental block with what to do first, second etc etc when putting these two things together because the tranny is not a rebuild ---- so it's a bit unclear about 'seating the tc', doing the fluid etc etc.
Is there a site with the steps laid out??
Gordon
Old 02-13-2011, 11:38 AM   #6
usmcchevy
usmcchevy's Avatar
To my knowledge the 80e never came behind the lq9, always a 4l65e.
First install the spacer, flexplate and bolt them in place.
Second seat the converter, easiest way is to set the tranny on its tail so you have gravity working for you. turn the tc 3 turns in both directions two times. while turning the tc should drop into place3 times i think. the tc bolt pad should then be 1" (1.030'')inside the bell housing, if not repeat turning until it is.
third bolt them together
fourth slide tc forward and bolt to flexplate
Build thread
LSx Swap FAQ index
Old 02-13-2011, 11:48 AM   #7
usmcchevy
usmcchevy's Avatar
more here
http://67-72chevytrucks.com/vboard/s...d.php?t=444788
Build thread
LSx Swap FAQ index
Old 02-16-2011, 11:49 AM   #8
Gordonr1973
Home Built '87
Thanks usmmchevy, I'm going to try what you suggested when I get my block back from the shop.
For anybody searching this thread topic: I bought GM part number 12621399 (new flex plate and adapter with bolts) and I ordered new bellhousing bolts as well.
I will put a detailed summary of how I mounted the tranny in my '87 build thread for anyone looking for that info. Thanks!
Gordon
