lower a-arms
im almost done! with my bags not the truck
#2 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: lower a-arms
(at the cross shaft bushing?) Any or all of the front end parts new? Or do you think you just have an electrical problem?
Re: lower a-arms
yes at the shaft with the bushings is tight i loosened the nuts and it got a little better but still no go and they are old i tried to have the bushings replaced at a shop and the guy said the arms were flexing and he didnt want to bend them, the upper bushings are new and operate smoothly.Now as far as the wiring i'm not sure whats going on. its pretty straight forward color coded but when i accuate a switch say #1 the right rear moves and its supposed to be the left front
![]() Last edited by 62 Bowtie; 02-10-2011 at 02:18 AM. |
Happy to be here
![]() Join Date: Mar 2000
Re: lower a-arms
Sounds like your supply lines are routed to the wrong valves.
Re: lower a-arms
thought that too so i moved the lines to a known good line and nothin in other words the lines work for the rear but when i remove the lines from the rear ports of the manifold and plug in the front lines to the same ports i get nothing heres a pic
