Old 02-09-2011, 06:47 PM   #1
jakeblues652
jakeblues652's Avatar
'67 disc brakes for a 4x4??
does anyone do this? kits? what needs to be done?? i hate the old drums, and if i can/ can afford it, i'll make the change.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 02-09-2011, 06:53 PM   #2
vectorit
What?
vectorit's Avatar
Re: '67 disc brakes for a 4x4??
The front axle is the old closed knuckle design, and you can convert them to disc. I know Blackbirds sells a kit, but most of the time I see people just swap out the Dana 44 for a later model one with disc/open knuck.
http://www.blackbirdscustomtrucks.com/index25.html
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-09-2011, 07:21 PM   #3
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
I didn't see it listed for a 6 lug closed knuckle on the blackbird site. Maybe they do and just haven't updated the website?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-09-2011, 09:06 PM   #4
The on;y drum brake Dana44 I know of that can easily be converted to disc is the open knuckle '70.
Old 02-09-2011, 09:14 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Mmm
Theres a junked 72 4x4 cheyenne at the junkyard. It makes me wanna 4x4, too bad your not closer you could steal the frontend out of it.
Btw, whats a ballpark price of a 4x4 lwb 72 frame with a 4" block lift? No transfer or motor/driveshafts.
John
1999 Toyota Tacoma 4x4
Old 02-09-2011, 10:16 PM   #6
jakeblues652
any advantage to the open knuckle over the closed?
Old 02-09-2011, 10:32 PM   #7
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Yes, much better turning radius and parts availability...that along with the advantage of disc brakes and its one of the easiest and best upgrades you can do.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-09-2011, 10:36 PM   #8
vectorit
What?
vectorit's Avatar
^^^What he said.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-09-2011, 10:57 PM   #9
jakeblues652
anything i should watch out for when finding an axle if thats the route i take?
Old 02-09-2011, 11:22 PM   #10
BLAZERMAN
BLAZERMAN's Avatar
Check your gear ratio you have now..probably 3:73s.. and make sure the axle you buy matches. Watch Craigslist, around here you can pick up a good Dana 44 or 10 bolt for under 200 bucks. 1971 to 1987 will bolt in but the 73 up axles have a little bigger axle u-joint and slightly bigger shafts which is a plus.
Old 02-10-2011, 12:33 AM   #11
jakeblues652
if i buy a 73-up, could i just dis mantle, and put my current gears in the axle housing?
Old 02-10-2011, 01:20 AM   #12
jakeblues652
fingers crossed that it is 3.73's. guess i'll find out when i pull the cover. my bud has a 71 half ton 3.73 axle.
Old 02-10-2011, 02:17 AM   #13
vectorit
What?
vectorit's Avatar
Check the dif cover bolts, and look for a tag.
Here is mine, and the tag will give info on the gear ratio.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-10-2011, 06:22 PM   #14
jakeblues652
no tag. but i did come across an open knuckle dana 44 around me for 100 bucks. the only thing is wrong gearing. anyone know if i could drop them in from my current axle to a new axle??
Old 02-10-2011, 06:42 PM   #15
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You might be able to but I can't remember for sure. Just make sure you don't end up getting a 10 bolt. Stay with a D44, 70-78 I believe.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-10-2011, 06:43 PM   #16
jakeblues652
the one im looking at for $100 is a dana 44 open knuckle from a mid 70's 1/2 ton.
Old 02-11-2011, 04:56 PM   #17
jakeblues652
can anyone help me??? i've been told the ring and pinion are a definate, but i may need a new carrier, depending on if the axle shafts are 30 spline or the other one(more splines on that one if i remember right). this sound right??
Old 02-11-2011, 06:24 PM   #18
vectorit
What?
vectorit's Avatar
I am no expert on axles, but there are differences on the axle diameter and spline count on various years/models of trucks that they came out of.
If I was in your shoes, and I had a line on a complete D44 for a hundred bones I'd snag it.
Then take it to a expert and have it gone through.
Ask the expert about your current axle, and inquire about re using the ring and pinion. They should tell you whether or not if it is interchangeable, and check to see of the 40 year old parts are still good.
If it were me, I'd spring for a complete overhaul with new matching gear ratio ring and pinion. I'd also price out a new locker, just in case they had a deal to offer me or if I could afford a new one in the first place.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 02-11-2011, 06:57 PM   #19
68chevyfuelie
68chevyfuelie's Avatar
Your ring and pinion should be fine to use on the newer diff. The older diffs might have had a coarse spline pinion, and might have had coarse spline side gears. What gear ratio do you have now, and what gear ratio is the newer diff?
68chevyfuelie is offline   Reply With Quote
Old 02-11-2011, 09:38 PM   #20
jakeblues652
i believe mine is a 3.73:1, maybe a 4.10 or 4.11:1. not quite sure. and the guy had 2, 3.5somethings, and 3.02 or something around there. they were relitivley high gears, i remember that. and i understand that some 67-71 danas were fine and some were coarse splines, and if i had fine, i could reuse the carrier. thats from what i read on a different sight, brought to me by a google search, so i have no clue how reliable the info is.
Old 02-11-2011, 10:04 PM   #21
68chevyfuelie
The carrier split on the old stuff is 3.73. So if you have 3.73 now, and purchase a diff with 3.08/3.23/3.54, your gears will swap to the other carrier no problem. If you have 4.10 now, you will have to reuse your carrier to do the swap. You might be able to just swap the side gears if you have coarse side gears, and want to swap to fine-spline side gears.
Follow me? If you have a coarse spline, 4 series, but wish to swap to a '72 up diff, you would have to use your carrier, the other carriers side gears, and your old diffs gears, to whack into the newer diff.
Otherwise, if you're playing with all 3 series stuff, it's much simpler. Cheers.
Old 02-11-2011, 10:30 PM   #22
Vintage Windmills
Vintage 4x4s
No need to pull the cover. Just turn the pinion by hand until the wheels make 1 full revolution and count how many times the pinion goes around. Just make sure both wheels are turning with each other while you do this otherwise the differential action will screw up the count.
Old 02-11-2011, 10:56 PM   #23
jakeblues652
thats all hanging on if they are both fine spline, right?? and just a random thought, could i just use the housing, and take the axle shafts and all and swap them, or would that make something mess up?
sorry for the dumb questions. i dont really like to get into axles normally, but for 100 bucks, i might as well try
Old 02-11-2011, 10:57 PM   #24
jakeblues652
and you can do the same thing by turning on the front too???
