Old 02-09-2011, 07:55 PM   #1
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
aftermarket disc brakes & 15" wheels
I'm planning on a future swap to disc on the front of my '70. I will be staying with 6-lug and using an aftermarket kit. I'm also wanting to keep my stock dog-dish hubcaps.
I haven't found my stock steel wheels yet, and have recently read that the 15" wheels will not clear the calipers... The sticky says so
I also read that the 73-87 16" 6-lug will work as the replacement.
So, is all the above information true? I just found me a set of 16"wheels locally and want to make sure this is the route to take or to hunt some 15".
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 02-09-2011, 08:30 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: aftermarket disc brakes & 15" wheels
The 71-87 4x4 steel wheels (made for hubcaps) are 15"
They should work fine for your dog-dish hubcaps.
They should also be cheap!
The 88-98 6-lug wheels are 16".
(I'm pretty sure they don't take a hubcap. Nothing to snap them onto)
They are the correct 6-lug bolt pattern,... but I would be afraid that they are the wrong offset.
(sucked in to far,... or too much backspacing)
Keith
Convert to disc brakes.
Old 02-09-2011, 08:32 PM   #3
lolife99
lolife99's Avatar
Also,... the only 15" oem 6-lug wheels that won't clear the disc brake caliper,... are the wheels made before the 1971 model year.
Keith
Old 02-09-2011, 09:10 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I have ECE (Early Classic) 2.5/4.0 drop. When I did the drop, I had 15x8's all the way around. The same wheels, when reinstalled back on the front, stuck out past the outside edge of the fenders. So, I swapped the 8's for a pair of 7's, up front. Problem solved.
I wanted Wheel Vintiques vette-style rallye wheels, so I ordered a pair of 15x8's up front, with a 4-inch backspace. In the rear, they're 15x10's, with a 5-inch backspace.
What won't work up front, are the original steel wheels for drum brakes. The backside of the wheel won't clear the brake caliper.
If you convert to 5-lug, the '71-88 wheels will work (5 on 5-inch).
Member Nr. 2770
Old 02-09-2011, 10:26 PM   #5
Mike J
vw guy & now c-10 guy
Mike J's Avatar
-yep, my 15x7 6-lug 4" backspace corvette rallyes fit just fine over my cpp disc conversion
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-09-2011, 11:17 PM   #6
SWEET7T
SWEET7T's Avatar
Just what I needed to hear.
Thank you all!
SWEET7T
