Old 02-09-2011, 08:11 PM   #1
Alaskan71
Alaskan71's Avatar
2WD to Symmetrical AWD?
This may not be realistically possible, but is there a way to change my 2wd chevy C10 over to a symmetrical AWD system like subaru by just changing out the transfer case, drive shaft, and rear diff? all while keeping my 350 with the possibility of upgrading later to a bigger newer motor?
Alaskan71 is offline   Reply With Quote
Old 02-09-2011, 08:29 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 2WD to Symmetrical AWD?
Yes, there is…
….buy a Subaru or a BMW X-drive car as a second vehicle.
Seriously, the closes you could realistically come to is to retrofit the GM truck Autocrap 4x4 system and even that wouldn’t be worth the hassle.
DirtyLarry is offline   Reply With Quote
Old 02-09-2011, 08:40 PM   #3
kSStamp0182
LSX addict
kSStamp0182's Avatar
my 01 has the autotrac. its quite useless. because you either NEED 4x4, or dont.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 02-10-2011, 10:10 PM   #4
Alaskan71
Alaskan71's Avatar
Alright, I was just curious and throwing around some different ideas. But thought I'd ask because you guys know a lot more than I do about it
Old 02-10-2011, 10:31 PM   #5
Zeke's Garage
Zeke's Garage's Avatar
It probably is pretty pointless, but if you wanted to pursue it, you could look into the AWD systems used on the Bravada, Typhoon and Syclone. Not sure how they would work with your existing diffs, and how much torque they would be able to take, but there are is lot of intereset in the Typhoons and Syclones, so I'm sure you can find a specific forum and get a lot more information.
I love how my Subaru outback feels on wet and loose gravel roads, and I think it would be fun to have a truck that drove that way as well.
it's only time and money... i say go for it.
EDIT: Just noticed you're in Alaska... yeah you need it. Really do it.
Shawn
Last edited by Zeke's Garage; 02-10-2011 at 10:32 PM. Reason: Holy crap! Geography!
Zeke's Garage is offline   Reply With Quote
Old 02-10-2011, 10:51 PM   #6
BIGBLU 72
BIGBLU 72's Avatar
ive been thinking about AWD for a while and why could you just cut down a Silverado SS frame to fit the body of a short bed?? it has to be able to be done?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 02-10-2011, 11:30 PM   #7
Alaskan71
Alaskan71's Avatar
Shawn
I have driven the bravado with it's Awd and it doesn't compare to subaru's Awd, audi's or bmw's. You are right I do live in Alaska and right now drive my 2wd year round with about 9 months of snow, so I thought why not take advantage of the snow and try to convert the Awd system to my benefit. I think having a truck that handled like a Subaru would be a pretty cool project
Old 02-10-2011, 11:30 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I agree that the auto 4wd on the newer chevys doesn't work all that great. I was at a dead stop in the snow in my 01 tahoe and set it to auto and all that happened was the rear tires spun, then I hit the 4wd button and it then I drove without spinning a tire. The 99 explorer that I used to have had the auto 4wd and it worked great it would drive around in 2wd mode until the rear had any tire spin and then it would instantly lock into 4wd. I had that in a foot of snow before with out ever setting it to full time 4wd and it didn't get stuck.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-10-2011, 11:36 PM   #9
Jacfourteen
Also I just wanted to mention that the 4wd setups on the newer chevys (at least on mine, not sure on others) isn't symmetrical, meaning it doesn't have a differential in the transfer case. what this means is that if you leave it in 4wd in high traction situations and try to turn it makes lots of noise and strain on the drivetrain, and also has less than desirable handling. The upside is that it has better traction slick conditions.
Old 02-10-2011, 11:38 PM   #10
Jacfourteen
With enough skill and money anything is possible, too bad I don't have enough of either to do a job like that! How well does the awd setup in an SS work in the snow?
Old 02-10-2011, 11:39 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
If it were me, I would pull the complete drivetrain from a Denali or Escalade.The AWD and 6.2 in my wifes Denali pulls that beast around like mad.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-11-2011, 01:35 AM   #12
Alaskan71
Alaskan71's Avatar
Thanks for the help guys, we'll see where it goes from here but it will be quite a project
Old 02-11-2011, 01:38 AM   #13
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
My 78 3/4 ton 4x4 is an allwheel drive. Wouldnt ya know haha. np203 transfer case. Drive slugs on the front wheels.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 02-11-2011, 01:42 AM   #14
Alaskan71
Alaskan71's Avatar
How does the Awd aspect of it handle? Lemon or better than a straight forward 4wd?
