Old 02-09-2011, 10:24 PM   #1
benaj
New vinyl floor help!
I just got a new vinyl carpet kit from LMC. This is the full kit that covers all the way to the back.
I can't figure out what is the front or the back? I have an 84 CUCV M1028. This is the 4X4 reg cab pickup. I don't want to cut out the hole for the shifter only to find out I had it backwards.
Anybody have any ideas?
benaj is offline   Reply With Quote
Old 02-09-2011, 10:54 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: New vinyl floor help!
Post a pic so we can help you ID front/back
bigblock73 is offline   Reply With Quote
Old 02-09-2011, 10:56 PM   #3
benaj
I will try and get some pics tomorrow.
Old 02-09-2011, 11:00 PM   #4
TheApocalyptican
TheApocalyptican's Avatar
based on this page: http://www.lmctruck.com/icatalog/cc/full.aspx?Page=120
It's either the end that is skinnier if its the Polyvinyl or if it's just the rubber floor mat on the top of the page, the front is the end that has the mounting holes farthest apart.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 02-09-2011, 11:04 PM   #5
bigblock73
yeller
bigblock73's Avatar
If there is a heel pad, then that is obviously the drivers side. The front appears to have an arch in the pic linked above, if that is the case, then that is the front and goes over the trans tunnel up against the firewall.
Old 02-09-2011, 11:06 PM   #6
benaj
The Polyvinyl is what I got. It unfortunately doesn't look like the picture. Its more square. I will try and post some pics later.
Old 02-09-2011, 11:12 PM   #7
TheApocalyptican
The other thing to do is to set it in the truck and try to match it to the low and raised spots where the seats sit. If it's anything like the carpet I ordered recently, it's hard to tell which end is which when in the house or garage, but once I put the carpet in the truck, it would only match the floor sitting one direction, so it wasn't possible to put it in backwards.
