Old 02-09-2011, 10:52 PM   #1
1984sgmc
lockout hub?
bought some premium warn lockout hubs for my 84 1/2 ton chevy, took the old mile markers out and i had to remove the snap ring and washer that was behind the lock out hub, without removing that the ring would not seat in the grove and hold in the new hub. my question is are the hubs going to get f#@kd up without having that washer in there.
and the warn instructions said on 85 chevys you may have to remove the snap ring
1984sgmc is offline   Reply With Quote
Old 02-10-2011, 11:31 PM   #2
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Re: lockout hub?
i saw some posts where guys said to put a big screwdriver between the flange and the knuckle and push out and it gives you the room to put the washer in. I believe that was it anyways, let me try to find the quote. I know on the auto hubs they had a second snap ring that you have to remember to get, but you have milemarkers already.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 02-10-2011, 11:35 PM   #3
Walts_restoration
Re: lockout hub?
http://coloradok5.com/forums/showthr...=warn+hub+auto
Post #4, if you have any other questions or problems just ask. Im about to swap the autos in my 86 for a set of warn premiums.
Old 02-11-2011, 06:58 PM   #4
1984sgmc
Re: lockout hub?
thanks that was pretty helpful. i put the hubs in without the little snap ring and the washer behind it. now i can spin the big ring like it was when the old ones were on there
