Recommendations??
...just wondering if there are any difference with brands (the quality and function) as far as with breathers and pcv breathers? Autozone sells some for a decent price, but what do you guys use or recommend??
- 1967 Chevrolet C/10 SWB fleetside (New Project). ![]() - 1969 Chevrolet C/10 SWB fleetside (SOLD) ![]() - 2000 Ford Mustang 232 (DD) - 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver) |
Grandpa in the rustmobile...
Re: Recommendations??
Wix oil filters is my only recommendation on that stuff..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
I only use Delco or Wix if no Delco is available-pcv, oil and fuel filters. For air filters either Delco, Wix, or K&N.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
For a PVC, any one from your local auto parts store is OK. For oil and air filters, Wix (NAPA Gold) is the only brand I use.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Wix only !!!!!!!!!!!!!!
71 C10 2WD,472 Big Block Buick B4B Intake,800 cfm Q-Jet built by(Fred Catlin) Comp Cam 254/268@ .050 .530/542 lift 1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's Mallory fuel system Igniter Flame thrower Ignition system TH350,Hughes 3500 Converter ,3.73's Its just an old heap, but its my hot rod! |
MOOG for suspension components
What's so special about Wix??? Never heard that brand before (since this is my first classic truck).
I dunno really. Nascar uses them I believe, my dad runs em. Ive heard good things about em, so I recommended them.
I learned about Wix when i was in Diesel school back in the mid 80's, got to see it and a fram ph8a side by side, hands down i have never run a ph8a since, even still had one in my garage and still sits collecting dust..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#10 | |
Quality in construction and more filtering media. Google them! http://www.wixfilters.com/productinformation/index.html
![]() Join Date: Dec 2010
i agree with wix or K&N for all filter products, but as far as a simple pcv valve go's i dont think it really matters, its just a way for the engine to vent the crank case. its not a filter really. just my opinion though.
![]() ![]() ![]() 71 gme Sierra Grande lwb. 68 Rambler American 2 door 75 jeep cj5 |
#12 | |
Yea i have no problem running a fram PVC ![]()
#13 | |
#14 |
Wis has more material per square inch and has a drain back valve and if you have ever purchased a Napa premium filter that is a Wix filter in a Napa box.
#15 |
OK...so what breather PCV (passenger side) and breather cap (driver side) do you all use?? Wix does not make it? Autozone/Kragens only over Spectre. I dunno if that brand is any good. If not, where do you guys get yours from? Summit? Jegs? Napa? If so, what brand?
FYI: I'm looking into a chrome cap cover type (PCV and Breather cap). LMK. ![]()
#16 |
Hand Crafted C-10
![]() Join Date: Aug 2006
What style breather are you shopping for...the kind that pushes into a grommet or the style that has a tang that locks in the valve cover?
The reason I ask is that I've seen, more than once, the tangs come off the bottoms of the latter and fall in the valve cover. The parts store chrome jobbers are notorious for it. .
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
#17 | |
#18 |
Go buy a PVC valve from the local auto parts store it will work fine. By breather do you mean the valve cover cap has a breather in it? If so that not a big concern, just get one that fits the valve over..
