apache rear end
i have a 61 apache. trying to find out what rear end i have. the center bolts on from the front but it has a cover on the rear. i want to change the gears out i have 411.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: apache rear end
The only designation I have found for that style of rear end is the GM55T. They were used from 1955-62. Gears aren't that easy to find for those rear ends. The only gears I know of are 3.38's made by Yukon Gear. What you currently have would be 3.90's
If I were you I would consider changing that rear end out for a truck 12 bolt. There are lots of options for those.
Re: apache rear end
I thought that I might add to the above in case you have a 3/4 or 1 ton. If so the 3/4 ton trucks usually had H052 axles with 4.57 gears and the 1 tons had H070 axles with 5.13 or something close to that. These were built by Eaton, Chevy used these While GMC seemed to use Spicer (later Dana) the 4.10 gears were available later in the 60s and 3.90 gears were available as aftermarket sets, which are no longer made. (or that I have been able to find new)
Where the hell did my coffee cup go?!! ![]() Last edited by pope; 02-10-2011 at 12:12 PM. |
Re: apache rear end
I forgot to ask what kind of ratio are you after?
Where the hell did my coffee cup go?!! ![]() |
Re: apache rear end
i want all 340s. right now i can only do about 60 tops on the free way. i want to be able to keep up. i think its a 1/2 ton. i have springs in the rear. how can you tell ??
Re: apache rear end
can i even do a 12 bolt. i was thinking nothing bolted up. i starting to think it might be cheaper to buy a 700r4
#7 | |
60-66 Nut
Re: apache rear end
Yes a 12 bolt will work. That's what I mentioned in my first post
Re: apache rear end
no its two wheel drive. i am pretty sure its 1/2 ton. it has a 327 and a t350 in it. with the stock rear end. so what would the 12 bolt come out of???
