Old 02-10-2011, 12:09 PM   #1
ROCKthe68
2 1/2" or 3" Exhaust?
I have a 396 in a 68 SWB and I am trying to decide what to do for exhaust. Planning on putting 40 series FM. Any suggestions would be appreciated.
TDY
ROCKthe68 is offline   Reply With Quote
Old 02-10-2011, 12:34 PM   #2
Solego
Dr. Frankentruck's Monster
Solego's Avatar
Re: 2 1/2" or 3" Exhaust?
Try posting in the engine section. Those experts should be able to give you a more technical answer for your set up.
I'm not prejudiced, I hate everyone.
Project SLOMO
http://67-72chevytrucks.com/vboard/s...d.php?t=430494
Solego is offline   Reply With Quote
Old 02-10-2011, 12:55 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I don't know about the 396 but I read somewhere on the 350 you can actually go too big and it hurts performance.
LockDoc
Leon
Old 02-10-2011, 01:49 PM   #4
clos69
Its Topless Season!!!!
clos69's Avatar
Those 40 series FM are way too loud for my taste....I would go with a bigger series like 50 especially if your putting them under the cab.... my .02
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 02-10-2011, 02:26 PM   #5
'70_402
'70_402's Avatar
2 1/2" pipe is fine unless you're pushing 500 or more horse... if it's a daily driver with street manners then go with 2 1/2" it'll be cheaper and you won't gain anything going bigger.
'70_402 is offline   Reply With Quote
Old 02-10-2011, 02:36 PM   #6
Quickshift-Perf
I'd say if you're pushing much over 500hp at the crank you should probably go with the dual 3".
Edit: Ooops, sorry. Missed your post but said the exact same thing lol.... My bad.
Mike
1968 C10 LWB with a glide...
Quickshift-Perf is offline   Reply With Quote
Old 02-10-2011, 02:50 PM   #7
cjohnson6772
cjohnson6772's Avatar
This may or may not be true, but I've heard that the bigger pipe is better for more horsepower on the top end, but that a slightly smaller pipe would be better for torque on the bottom end. From a back pressure standpoint I think this makes sense.
Also 3 inch pipes will be unbearable unless you're 17 yr old or have 7 layers of dynamat.
Once again though this is just one man's humble opinion.
cjohnson6772 is offline   Reply With Quote
Old 02-10-2011, 03:07 PM   #8
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Is your 396 modified, larger cams, head work, headers? If so, the 3" would work ok. Otherwise, go with the 2.5". The smaller exhaust will, in most cases, yield better torque, and will be easier to route.
If you like the look of a bigger pipe, just do the tail pipe in the 3".
Zoomin is offline   Reply With Quote
Old 02-10-2011, 03:26 PM   #9
Ole Greenie
Ole Greenie's Avatar
I have a LS6 454 and just installed 2.5" piping and 40 series Flowmasters....but I also installed an "X" pipe under the cab. (Not an "H" pipe) Mufflers were attached under the bed. I'll post pictures when I get home.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 02-10-2011, 03:29 PM   #10
tubbedII
needs more $$$
tubbedII's Avatar
I had a mild 454 in my camaro with 2 1/2 at first, and switching to 3" just made it louder. It never really made much low end torque so it was hard to say it lost any by the bigger pipes.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 02-10-2011, 04:49 PM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
Totally agree with this thought path. There is a breaking point for performance and it all hinges off of the collapse of exhaust gases from the engine and the resulting reversionary pressures that are resultant of the early collapse. Unless you are going to run the engine hard, then the 2 1/2" will support your needs.
Frank
piecesparts is offline   Reply With Quote
Old 02-10-2011, 04:57 PM   #12
kwmech
3'' single. Plenty of flow. Less 'stuff' under the truck. Decent sound. Got a 3'' single on my 68 with a semi-built 454, more than enough. Pipe runs hotter....less rust
Old 02-10-2011, 06:33 PM   #13
Ole Greenie
OK....Here are a couple pictures of the 2.5" pipe I installed a couple weeks ago:
Again 2.5" pipe with a "X" pipe and flowmaster 40's.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 02-10-2011, 06:42 PM   #14
lakeroadster
Here is a helpfull chart. Pick your estimated horsepower and find the appropriate exhaust diameter:
lakeroadster is offline   Reply With Quote
Old 02-10-2011, 11:38 PM   #15
ROCKthe68
How much was this setup if you don't mind sharing?
TDY
Old 02-11-2011, 10:29 AM   #16
Ole Greenie
This install cost $400 not including the polished stainless magnaflow tips I bought that dump right behind the rear tires. Add $104 for the tips. All materials and labor was $502.00. (Pics of tips and rest of truck coming after I get it back from the paint shop.)
I would like to say however about eliminating drone.. Eliminating loudness and/or drone can be accomplished many ways:
1) For true dual...Add a section of tube perpendicular to each of the exhaust tubes prior to mufflers. This will remove sound waves to a great extent as they would reverb throughout the length of the added tube. Tube will have to be cut to a certain length to minimize sound dependent on the frequency and amplitude of the sound wave.
2) Decrease the diameter of the exhaust tube.
3) Install an "H" or "X" pipe. "X" pipe is better at this than the "H" pipe.
4) Install a resonator before the muffler.
Hope this helps...
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 02-11-2011, 10:37 AM   #17
dznucks
dznucks's Avatar
Not sure if your truck is lowered or if you are thinking about lowering it. And not sure about how you want it routed.
But the 3" pipe will be more difficult to hang "high and tight" and get over the back axle if you keep it between the frame rails.
I put 2.5" under mine with an x-pipe and love it. 3" is too big unless you running some type of forced injection or huge heads and cam on a large displacment engine.
You should expect to spend around $300-400 in labor for a decent exhaust job.
dznucks is offline   Reply With Quote
Old 02-11-2011, 10:46 AM   #18
Ole Greenie
agreed... the lower the more difficult. 3" piping is difficult to work with period. Mine is lowered 3.5"/4" and it was a bear fitting it up and over the axle and then up and down again inside the fender well to get the desired look I wanted. Bends also decrease the loudness associated with larger diameter pipe.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 02-11-2011, 06:03 PM   #19
llowlife
If your plan is to not lose HP due to the exhaust then plan on 2.2 cfm of flow per hp. 1 sq. inch will flow 115 cfm on a short straight pipe with no bends. Frankly the FM's will be the restriction even with 2.5" pipes.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 02-11-2011, 07:39 PM   #20
lakeroadster
Ironic that "Flow - Masters" aren't "Masters of Flow"
I am assuming Cherry Bombs (glass packs) are less restrictive than Flow Masters. Anybody know of any flow testing that verifies this?
Old 02-11-2011, 08:13 PM   #21
Ole Greenie
Shoot...along this line of thinking just run straight pipes!
The chamber design of any muffler interrupts the flow of gases through them. This interupts the frequency and amplitude of the "signal" through the tube. Since Glass Packs silence this effect through holes in the side of the pipe into the fiberglass surround I would imagine that they do flow better. I just cant get to appreciate their sound.
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
Old 02-11-2011, 08:21 PM   #22
lakeroadster
With full length tail pipes glasspacks sound great, IMO. To me Flowmasters sound like a motor running under water.
Old 02-11-2011, 09:47 PM   #23
jakeblues652
jakeblues652's Avatar
couldnt agree more.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 02-11-2011, 10:51 PM   #24
todd99
I have a 350 and was running ceramic flowtech headers and 3" pipes with flowmaster 40's. It was seriously lacking torque so I added an x-pipe and heat wrap and now it runs like a raped ape.
todd99 is offline   Reply With Quote
