Easy Does It
Parking Brake set up Pics. ???
Any good pics of the parking brake cables set up .I found a pic. on here awhile back showing where the front and rear cables attached and now I cant find it .
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Parking Brake set up Pics. ???
what year?
60-63 I think are the same, 64-65 are the same but different from above 66 is different than the others
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Here is a link to a 66gmc e brake set up
http://kieth.smugmug.com/Trucks/66-G...35654459_TEXEE go to the next page and you can find other views....Kieth |
Easy Does It
the truck is a 63' but its not factory, and I dont have any factory brackets and such, im looking for a custom set up using factory cables , i saw one on here before but now I cant find it???
Kieth's pictures show a 66 set up.
The 64-65 have a lever assy attached to the transmission crossmember. I really dont know about what the 60-63 have. Sorry I am not much help for you. Here is LMC's page 89 that shows the parts you would need, looks like 60-62 is alike, 63 is by it's lonesome, 64-65 are the same and 66 are different that all the others. http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=89
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! Last edited by Clyde65; 02-10-2011 at 05:13 PM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The '66-'72 parking brake cable assembly would be the easiest to retrofit to your truck.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-10-2011 at 05:50 PM. |
When I bought my truck it didn't have the parking brake cables hooked up, or the crossmember with the lever mechanism.
I made one to use with the stock handle. Then later on I installed a floor mount parking brake and reworked the lever mechanism as shown below. Basically I used some old shifter linkage to make a spliter bar and a spring I bought from the local hardware store. Hope this helps, John Last edited by lakeroadster; 02-10-2011 at 06:31 PM. |
