02-10-2011, 01:34 PM | #1 |
under hood start
Is there a way to start an engine from the engine compartment? I have a few issues that require me to watch the engine while starting it. Is this something I can buy from an autoparts store, or is it something I can put together myself?
02-10-2011, 01:41 PM | #2 |
Re: under hood start
remote starter switch found at most auto parts stores for cheep
Fuzzy |
02-10-2011, 02:28 PM | #3 |
yep.. i have one perm. mounted for adjusting valves...
https://www.ebay.com/itm/29620574751...mis&media=COPY |
02-10-2011, 02:45 PM | #4 |
I just used mine this past Sunday to spin the electric starter I installed on my previously pull start only 1987 Evinrude 25hp.
For a while i had it permanently installed on my 1971 Monte Carlo. The "On" part of the ignition switch worked but the "Start" position was hit or miss. I simply turned the ignition on, hit the button, and I was off to the races. Everybody should have one in their toolbox.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
02-10-2011, 03:00 PM | #5 |
I have one now. Thanks for the advise!
02-11-2011, 12:23 AM | #6 |
You will still need to put power to the coil to make it run...
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-11-2011, 12:28 AM | #7 |
Junior Member
I bought one at a local parts store for less than $15 last year. A lot handier than the old screw driver trick.
If you use the remote start make sure it is in park if an automatic or neutral if a manual.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
