Old 02-10-2011, 03:23 PM   #1
allengator
allengator's Avatar
Are square body duallys ONE TON??
Are square body duallys ONE TON?? or??
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 02-10-2011, 03:44 PM   #2
Jonboy
Slots go on anything!
Re: Are square body duallys ONE TON??
Yep. 1 ton.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-10-2011, 04:07 PM   #3
allengator
allengator's Avatar
Thanks...
I'm thinking of finding or building a 1 ton box truck for my band!
Allengator
Outta the Blue
Old 02-10-2011, 04:16 PM   #4
Jonboy
I don't know how hard that will be. Most of the box trucks I have seen are on a van (P series) chassis. If you could find an old Ambulance, that would work, too.
Old 02-10-2011, 05:29 PM   #5
C-10 simplex
i've been thinking about doing the same thing except instead of a box i'd like to go flatbed/stake body.
Could taking the box off of a 1-ton pickup be feasible? Aside from the rear track being wider---pickup would be wider vs. chassis cab's track would be narrower, are there any other differences? Are the frames generally the same shape behind the cab?
2) As far as finding one these might be a good sources:
http://www.commercialtrucktrader.com/
http://www.truckpaper.com/drilldown/...=293&bcatid=27
3) P.S. another alternative might be to consider those isuzu cabover box trucks.
C-10 simplex is offline   Reply With Quote
Old 02-10-2011, 06:38 PM   #6
87 V20 Scottsdale
87 V20 Scottsdale's Avatar
I assume you're talking about a truck like this one, just with an older cab. http://www.truckpaper.com/listingsde...?OHID=1927760&
They're out there, if you look long enough I'm sure you can run across one.
Andrew
1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10
1988 C1500 Scottsdale 305, 700R4, 3.08
1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10
87 V20 Scottsdale is offline   Reply With Quote
Old 02-10-2011, 06:43 PM   #7
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
One thing someone hasn't mentioned is the difference between the cab and chassis and the regular one ton duly fleet side. The regular one ton's are wider.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 02-10-2011, 07:25 PM   #8
Prerunner1982
Prerunner1982's Avatar
See post #5..
I think something like this would make a good "box" truck..even has rear A/C and a place to sleep. But that is probably just me. It is a M1010 by the way.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-10-2011, 07:28 PM   #9
GM72K10
Next!
GM72K10's Avatar
Square body C&C can actually be 2 tons or more depending on the body. My 86 K30 C&C has a 11,000 gvw. The 1 ton dually pickups were only 10,000 gvw.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
