Old 02-10-2011, 07:22 PM   #1
dccarpenter
Key won't turn, Wheel Locked, Should I pull wheel?
Hiya,
Seems I have 99 problems and no answers with my truck recently....just converted my '84 c30 350sbc with a turbo 400 to a sm465..
Got the swap done and everything was working ok..(other than the transmission that I took the seller's word for was running great and found out had a 3rd gear that popped out but anyways.....) until this afternoon, I went to turn the igition to on to start the car and it won't turn. I looked under the dash at the column and the rod that's connected to the ignition works fine if I push it manually in. What has happened is that I turned my wheel so hard , repeatedly, that it locked itself in a way that the igntion cylinder is stuck. Do I need to pull the wheel off to free the column up? Will pulling the wheel free it up or are there other measures that need to be taken?
I know the lock cylinder is ok as it turns towards me to turn the radio etc..on.
As for why I was pulling the wheel so much, I had just gotten home with a new belt for the steering as the old one was going and had loosened and so it was squealing and was hard to turn when stopped, I was turning my wheels as I was parked on a hill and didn't want to roll (until I fix my ebrake...which is also now acting up). I guess I was turning it so hard I locked the ignition..at least that's what I gather from a google researching of this phenomenon.
dccarpenter is offline   Reply With Quote
Old 02-10-2011, 07:26 PM   #2
jchav62
1962 C-10
jchav62's Avatar
Re: Key won't turn, Wheel Locked, Should I pull wheel?
Try wiggling(turning) the steering wheel back and forth as you turn the key. Sounds like the like may be binding. This happens to me sometimes.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-10-2011, 09:37 PM   #3
dccarpenter
Thanks a lot for the info, I got it working. Really appreciate the help from everyone here, scraped together the $ to register even!
