02-10-2011, 10:36 PM | #1 |
60-66 outer rear view placement...
I need to locate the outer rear view mirrors. I purchased brand new after market mirrors and need to know where to place them...
Need measurements/placement. Thanks in advance. Jesse
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 Last edited by REDNOSE65; 02-10-2011 at 10:36 PM. |
02-11-2011, 12:58 AM | #2 |
Re: 60-66 outer rear view placement...
What kind of new ones? are they repros of the stock ones?
"Always try to make the best part you can with the skills you have. If it isn't good enough throw it away and make another. Every time you make a part your skill will increase and you'll make a better part than you were capable of making before." Lil John Buttera |
02-11-2011, 09:38 AM | #3 |
If you're talking about the standard stock mirrors, the drivers door had factory welded nuts on the inside. The Pass. door has a plate with the holes pre-drilled all you need to is punch through the otter skin. My doors are being painted right now and the painted had to sand down through the bondo layer so I can see where to drill out the holes.
Hope this helps, if you look in your door you should be able to see the plate I'm speaking of.
http://s1299.photobucket.com/user/jb...23904108567829 |
02-11-2011, 11:33 AM | #4 |
Here's what I have:
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 |
02-11-2011, 12:08 PM | #5 |
Check The Champ, Demonstrator
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 02-11-2011 at 12:09 PM. |
02-11-2011, 12:36 PM | #6 |
Thank you every one. The holes were welded shut. I will have to use the original screws with nuts inside the door. I'm trying to figure out where exactly to mount them...as close to the original place as possible.
02-11-2011, 12:47 PM | #7 |
I hate when PO's do stupid stuff like that, BUT having said that it was HIS truck to do what he wanted.
If thats the case, take the drawing above and just move them down 3/4-1" and put 3 holes in the skin and use either lock nuts or lock washers and nuts I have to do this on my passinger side.
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 02-12-2011 at 11:35 AM. |
02-11-2011, 12:50 PM | #8 |
1965 Chevy C10, 2005 4.8L/4l60
I just reached through the inside of the PS door and used a punch that you push on and it pops to make the dent, then repunched from the outside and drilled the holes.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-11-2011, 12:52 PM | #9 |
Thanks fellas.
02-11-2011, 01:09 PM | #10 |
red, if you want you can take a pattern off mine, LMK.
02-11-2011, 01:12 PM | #11 |
Thanks. I'd like to...where are you located Clyde?
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 Last edited by REDNOSE65; 02-11-2011 at 01:13 PM. |
02-11-2011, 02:59 PM | #12 |
I am located in south Ft worth. just west of Mansfield.
02-11-2011, 03:11 PM | #13 |
Senior Enthusiast
02-12-2011, 08:40 AM | #14 |
Senior Car Nut
good suggestion about the nuts. here's measurements from mine:
Larry |
02-12-2011, 01:01 PM | #15 |
Thanks Larry. That actually helps alot.
Clyde, If worse comes to worse, I'll get with you. Thanks alot!!!
02-12-2011, 01:19 PM | #16 |
sure thing Red
02-15-2011, 12:48 PM | #17 |
02-15-2011, 01:00 PM | #18 |
Red you selling your truck?
02-16-2011, 10:19 AM | #19 |
02-16-2011, 10:55 AM | #20 |
wow, there is one just like yours on ebay and I was just thinking. that is really weird.
I cant find it now.
02-16-2011, 05:19 PM | #21 |
Senior Enthusiast
Just a note, most of the trucks I've seen (including mine) with the factory nuts inside the door skin mount the mirror parallel to the style line on the door. As indicated in the schematic above by Aerotruk, they are level, not uphill in the front. Perhaps this changed over the years and the newer trucks are different. Just thought it was worth mentioning.
02-17-2011, 10:26 AM | #22 | |
02-17-2011, 10:42 AM | #23 |
That blue one with the red primer spots just sold on Ebay for 5500. I had been watching the listing. Sean
02-17-2011, 10:58 AM | #24 |
Cool man. I like it. I just stole the pics because that's the angle I was trying to look at.
02-17-2011, 11:01 AM | #25 | |
