1965 Chevy Wiper Problem
When I turn off my wipers they "park" pointing up...instead of laying flat. What have I done wrong?
Re: 1965 Chevy Wiper Problem
remove the arms and reposition at the lower position
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
60-66 Nut
![]() ![]() Join Date: Mar 2007
It sounds to me like there is an internal problem with the wiper motor that isn't letting the wipers park in the correct position.
sorry to cut in but, since you were talking about wiper problems....i think i smoked my 6 volt motor is there a twelve volt that fits from another year?
If you used to be...then i guess you never were. |
![]() Join Date: Aug 2009
by you saying wrong i assumed you had removed the arms, if not your wiper motor may be bad if so dont pay the big dollars from the specialty companies oreillys has them new in the 2-Speed With 3 Terminals for 49.00 bucks or the 2-Speed With 4 Terminals fo 61.00 bucks and these are also used on 1974 - 1978 jeep Cherokee, J10, Wagoneer and Wagoneer Custom if you happen across one in a salvage yard
it ran super fast like a 6 volt on a 12 volt battery. ive had plenty of sixties vehicle that were 6 volt so i assumed that the truck came with a 6 volt system. this is my first 65 pick up. at any rate it quit on me.
If you used to be...then i guess you never were. Last edited by bobbylast; 02-19-2011 at 12:00 AM. |
60-66 Nut
There aren't any '60's GM trucks that were 6 volt.
Intentionally Left Blank
The arm on the motor is on 180 degrees out. If you just move the arms they will try to go down and onto the hood. I just did mine about 2 months ago.
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
