03-15-2003, 11:42 AM | #1 |
aka Crusher, Crushergmc
Are there different pitman arms for power steering boxes (2wd)?
I'm having trouble clearing the lower A arm with the inner ball joint due to the fact that I notched my crossmember 1.5". It would be nice just to change out the pitman arm to something with less of an offset. Thanks.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
03-15-2003, 09:51 PM | #2 |
Anybody? A simple yes or no will do. Details would be great but...
03-15-2003, 10:03 PM | #3 |
Designated Grumpy Old Man
I was talking to the guy that I bought my last power steering box from about changing my manual box to a power steering box. He suggested also changing my pitman arm also as it had a differant angle to it. You might find a manual and a power steering arm and compare them. If I can find his card I will PM you with his phone number.
Good luck
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
03-16-2003, 10:09 AM | #4 |
Fabricate till you "puke"
I dont think you will find a pitman for the power box with a different offset, unless somebody has an aftermarket version. you might talk with Turner enterprises, as they do notched crossmembers......maybe they have dealt with the problem. i had to take a look at my 69(it has a stock crossmember), but it does look like there could be interferance issues with the inner tierod, with a dropped crossmember. Are you using the 67-72 arms, or the 73 up style?
03-16-2003, 12:59 PM | #5 |
HMMMM
Can't really say on the angle but I did notice that the splines were different 1 was smaller circumference than the other 1 I swapped out from manual 2 power on 69 2wd
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
03-16-2003, 01:14 PM | #6 |
Thanks fellas. I was going through the LMC catalog and they only show one power steering pitman arm. That goes along with your post and what I've heard from others. I guess I'll have to slot the mounting holes so I can raise the box .25".
