02-11-2011, 09:16 AM | #1 |
1970 350 Compression ratio
Does anybody know what the factory listed the compression ratio for on the 350/4bbl/4spd engine in '70? I think it's the original engine, it has 441 heads with June '70 date code, I can't see the block casting number, but I assume it's the usual 0010. The code stamped on the pad in front is VO622 TBB, which matches. I'm going to guess 9:1. Thanks in advance.
02-11-2011, 09:47 AM | #2 |
Re: 1970 350 Compression ratio
8.5 i think is closer
02-11-2011, 10:07 AM | #3 |
2WD Jimmy
Our 69 3/4 ton GMC with the 300hp 350 was 10to1... that is/was stock. Gas was cheaper and better.
02-11-2011, 10:28 AM | #4 |
Who's got steelies?
From the Specifications and Technical Data at the back of the 1970 10-30 series owner's manual:
Engine 350 V8 Color Code Red Piston Displacement 350 Compression Ratio 9.0:1 Gross HP 255@4600 Net HP 200@4000 Gross Torque 355@3000 Net Torque 310@2400 Hope that helps!
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
02-11-2011, 10:48 AM | #5 |
10:1 350/300hp truck motor??? I don't think so. Never heard that before. If someone can prove me wrong I'd like to learn something.
02-11-2011, 11:24 AM | #6 |
that must b the elusive corvette optioned truck
02-11-2011, 11:24 AM | #7 |
DND Trucks
Compression ratios vary a little from engine to engine, more or less. I'd perform a compression test just see where it's at now.
As far as a factory installed 300 hp and 10.0 compression 350 in '70 in a truck? Never seen one, nor does the GM basic engine data and power teams list any combo. Now a passenger car, that's a different story. Last edited by Dave; 02-11-2011 at 11:27 AM. |
02-11-2011, 09:33 PM | #8 | |
02-11-2011, 11:00 PM | #9 |
71 c20 longhorn custom camper. My motor was completely stock and had 11 to 1 compression, I had to check it twice just to believe it. My heads are stamped with 3978487 K250, not sure if that means anything.
02-12-2011, 12:05 AM | #10 |
That's nothing! My stock 350 in my 71 is 19:1. That's why I have always had to run premium.
02-12-2011, 12:10 AM | #11 |
^^^ Are you mocking me?
02-12-2011, 12:18 AM | #12 |
02-12-2011, 12:21 AM | #13 |
No worries, I'm not making it up. I am far from the original owner, it's possible someone tampered with it before I bought it. It looked stock.
