Old 02-11-2011, 09:25 AM   #1
skeeterbug
skeeterbug's Avatar
rear disc & 15" vintiques wont work?
well in preperation for test and tune @ the local i ordered a set of 15" wheel vintiques 5x5 5" bs 10" wide, i was wanting 5.5" backspacing like im runnin on my 22's but they are not available that way. well turns out that should have been the least of my worries, when i done the frame off on my truck i upgraded to wilwood d52 calipers and astro van rotors on the rear axle. and of course beings i put coy 22's on the rear to finish off the rebuild i didnt run into any issues with the calipers rubbing the wheels, well now i have. so the question is all of you fellow racers w/ rear disc 5 on 5 pattern what wheels are you running or how did you all solve this problem?
thanks,
skeeterbug
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 02-12-2011, 12:23 AM   #2
SCOTI
SCOTI's Avatar
Re: rear disc & 15" vintiques wont work?
Post up some pics of where the interference is. The D52's fit within a factory 15" disc brake type wheel up front so it should work for the rear as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-12-2011, 12:52 AM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I did a C-5 rear disc conversion and they fit under a factory steel wheel with a small spacer.. or grind the caliper bracket down just a bit.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
