Old 02-11-2011, 03:01 PM   #1
jserrato714
jserrato714's Avatar
cant fit 22"s on 68 c10 swb rear hubs
Hello peeps, so I came across some 22" 6 lug wheels off of a 2001 yukon. I installed the two fronts and let me tell you..it looks tuff. ( pictures are on there way). I am trying to install the rears but the center wheel hub is about 1/2 inch bigger than the center hub hole on the wheels..Any ideas as to what I need? Can I just grind the rear spindle hub flat? I am on a budget here so replacing the wheels is not an option! Thanks to all....Note: I have researched but cant find nothing on the rears just the fronts.. Thanks 2 all
jserrato714 is offline   Reply With Quote
Old 02-11-2011, 03:03 PM   #2
RickBost
RickBost's Avatar
Re: cant fit 22"s on 68 c10 swb rear hubs
i am suprised that you got them over the front hub i tried to install a set of stock 17s off of a tahoe on my 67 but i wouldnt grind down the the center. i would look for a different set of 6 lug drums for the rear.
72 GMC Jimmy 8" lift 38" super swampers
77 GMC C15 High Seirra Short Step lowered 6/8
http://67-72chevytrucks.com/vboard/s...53#post8999053
1972 Plymouth Roadrunner
2005 Cadillac Escalade
2014 Ram Ecodiesel
RickBost is offline   Reply With Quote
Old 02-11-2011, 03:13 PM   #3
jserrato714
Well the front has a disc brake set up now so that when in perfect... The drums in the rear are not the problem its the I think its called hub where the lug bolts are. The center piece is a 1/2 to big to fit the center bore on the wheels...
Old 02-11-2011, 03:37 PM   #4
colin_havens
colin_havens's Avatar
I wouldnt grind down the center hub. Do you have enough room that you could space them out just enough to clear the rear hub? There are several companies that make billet spacers that are hub centric to both the axle and the wheel, so you still get the stability of being hub centric, and you would get more of a flush fittiment on your wheel.
colin_havens is offline   Reply With Quote
Old 02-11-2011, 05:38 PM   #5
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
That sounds like the easiest fix, if you can afford the extra width. If not you could probably take them to a machine shop and have them bored out a bit. Let us know how it turns out because I have a six lug rear I'm getting ready to swap in and I figured the late model rims are cheap so I'll probably get a set of those.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 02-11-2011, 05:44 PM   #6
c10seconds
c10seconds's Avatar
Take your axles out and take them to the machine shop to have hubs turned down. It might cost $80?
c10seconds is offline   Reply With Quote
Old 02-11-2011, 05:53 PM   #7
esosa67
esosa67's Avatar
im getting a set of wheels from a 2001 as well, they were on a bagged chevy so i think the offset will be ok, but i have not tried them on yet but will, i'm planning to do disc brakes all around but we will see for now i want to put the wheels on but dont think its gonna happen with the hubs, i was going to widen the wheel hubs but not sure on the safety? i got a machinst to do it for $40 each when im ready.
esosa67 is offline   Reply With Quote
Old 02-11-2011, 06:29 PM   #8
jserrato714
I guess the easiest thing to do would be to find a place that can make the wheel bore a bit bigger..My wheels are currently not hub centric and I have not yet had any problem with them being lug centric...I have to find a local shop here in orange county ca that can do this.. Any ideas ?thanks to all!
Old 02-11-2011, 07:00 PM   #9
scrapmetalart
Junior Member
it only cost me $10 when i had my axles redrilled to 5 lug...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 02-12-2011, 01:05 AM   #10
travlinman
i ran into the same problem on my 69 with the newer wheels. i took them to a custom wheel shop or a wheel shop that fixes curbed or bent wheels and they put them on a machine and drilled out the center bore on the wheels. think it was like 40 a wheel?
good luck and wheres the pics!!!!
94 ls swap silverado
65 Pontiac
78 c30 crew cab dually (parted and gone)
82 c30 crew cab dually ( now building )
91 r30 crew cab dually (parted and gone)
69 swb-sold
71 lab sold
all in progress......__
..........._______ |__\__
..........|__(O)______(O)] ........................
travlinman is offline   Reply With Quote
Old 02-12-2011, 08:00 PM   #11
jserrato714
Yeah I found a local shop in Orange County that will make the wheel bore bigger for me for $40 a wheel... Now the only problem is that my truck is to low. I put the front wheels on and it looked great, only problem was that the tires were rubbing enough that I cant turn my wheels but it looks great lol. I am on a budget so new tires are out of the question.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 05-21-2015, 06:44 PM   #12
thumpros@yahoo.com
thumpros@yahoo.com's Avatar
Group, I too am planning to mount Chevy Tahoe 20" on my 68 C10. Has anyone resolved rubbing issues and Wheel clearance on dropped early C10's? Please share success formulas with us. Thanks
68 C10 LS SWB LM7 5.3 700R4 http://67-72chevytrucks.com/vboard/s...d.php?t=692803
thumpros@yahoo.com is offline   Reply With Quote
Old 05-21-2015, 07:53 PM   #13
thumpros@yahoo.com
Did Center Boring the rims/wheels solve all your issues? I'm heading towards this same part of my 68 C10 build and i want to mount the 2004-2014 Tahoe 20" on mine. What was your final successful combination to run late Chevy truck wheels on classic Chevy s'. Thanks.
Old 05-21-2015, 08:54 PM   #14
jserrato714
I have pm you with the info . My wheels center bore were big enough however the lug nuts are super small on these trucks. You need E.T style lug nuts size 7/16'-20 if you still have the original 6 lugs. This will correct that problem of the wheels not being hub centric but rather lug centric.
Old 05-22-2015, 11:30 PM   #15
thumpros@yahoo.com
Awesome response and plain enough language that even I (ASE Certified Tech) can understand. Thanks -a-million. I will order my BAER 4 wheel Disc setup and have a solution for wheel fitment when we cross that bridge.
Awesome!
Old 05-23-2015, 08:40 AM   #16
I think these trucks are trying to tell you guys something
