Retired Air Force Veteran
![]() Join Date: Aug 2007
Firewall hole? Whats it for
What is this hole for and where can I get this grommet
(its between the steering column and gas pedal) ![]() ![]()
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 02-11-2011 at 03:27 PM. |
![]() Join Date: May 2007
Re: Firewall hole? Whats it for
Looks like the clutch linkage hole.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
well it was an I-6 with a three on the tree so that make sense. thanks
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
i'd measurethe diameter of the hole and go to lowes or ace hardware boat supply stores too and look for the right size hole plug as the cheap way to close it up//dont ferget to bring a tape measure with you
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 02-11-2011 at 04:28 PM. |
What?
Clutch linkage.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
If you had an auto trans it would have a metal plate over that hole
Fuzzy |
Well I was trying to post a picture for you to see how the factory covered it but I can't post a pic. Not sure if the site has something going on or not.
This is the cover my 72 auto has.
harry you need a 67 70 caplugs silver plug it is the same type of plug that is on the door jamb of the doors
When I got mine that hole was used to run the mechanical oil line through an it had a grommet on it surprisingly lol
Posted via Mobile Device |
Here's a pic showing what is supposed to be there?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
