Old 02-11-2011, 09:37 PM   #1
brawley
Easy Does It
brawley's Avatar
need adjustable column shift linkage
I have a 350/350 combo, I moved my engine back to the rear mount holes, I have an auto shift column, I have a measurement of 24" and need a shift linkage, what have you guys used?? the lokar only measures out to 23"
brawley is offline   Reply With Quote
Old 02-11-2011, 11:37 PM   #2
blackmopar
Re: need adjustable column shift linkage
the lokar one is a bit short - but i managed to fit it and it works great - need to make 1 bend to clear bellhousing - i have the same combo as you in rear holes
blackmopar is offline   Reply With Quote
Old 02-12-2011, 10:50 AM   #3
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
X2
I had to re-clock the arm that mounts on the tranny to get it to reach. It is fully extended to the max, but works great
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 02-12-2011, 11:20 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Me too! when I put the 4l60e in, needed its entire length.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-12-2011, 11:43 AM   #5
padresag
you can more than likely make the shift rods a little longer
ron
padresag is offline   Reply With Quote
Old 02-12-2011, 11:52 AM   #6
blackmopar
Originally Posted by AZ66GMC View Post
X2
Tony
thats right - i forgot that - the lokar instructions say to postion the trans arm at like 8 oclock - I would up more like 11 oclock really
