03-15-2003, 03:33 PM | #1 |
Used to have a truck
rare Dana 60 parts
3.54 geared Dana 60 coil spring rear end. I know some of you think they dont exist but this one if proof they do. Ive sold the powrlok out of it but I will be reinstalling the original open carrier into it this week. $175 . This one has the panhard bar mount cast into the housing. Ive never seen another one on a 67-72.
4 series Power lock carrier for Dana 60 . Fits 4.56 and numerically higher gears with 30 spline axles. Hard item to find to be sure . $200 4.10 Dana 60 gear set . Excellent condition . Free to good home to whoever buys the 3.54 geared dana 60
No truck :-( |
03-15-2003, 06:02 PM | #2 |
Project Junkie! Fishing Poor!!
I know they exist, I have one under my 67 3/4 ton. They were mostly istalled in BB 3/4 ton Suburbans. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
03-15-2003, 11:58 PM | #3 |
I have one too.. a 3.54 Dana diff from a 70 gmc 3/4 ton coil sprung.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
03-16-2003, 12:03 AM | #4 |
I never could figure out why GM would include the danas in some and the eatons in other similarly equipped trucks. Mine was a big block Close Ratio 4 speed truck when it was new and it and a Dana but I have seen big block 4 speeds that had eatons in them too ? I thought it was maybe the heavy duty rear springs that pushed it over the limit but I have seen C30 1 tons with eatons under them?
No truck :-( |
03-16-2003, 12:16 AM | #5 |
"Ochre Ogre"
I have 3 of those very rare dana 60's, coil sprung and all posi. I had 1 leaf spring dana that came in a 72 GMC 350/4spd.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
03-16-2003, 12:22 AM | #6 |
I have one for a 1/2 ton 6 lug. Totally rare
1957 Cameo |
03-16-2003, 12:44 AM | #7 |
I dont think Ive ever seen a 1/2 ton dana 60. Not under a 67-72 Chevrolet anyway . Werent they more common in the 60-66 range ? Must be a semi floater. Those must be the basis of those jeep dana 60 conversions I see. Is your 6 lug a leaf or coil Dana ?
Confusing history on Dana 60's. Everyone used them but no one kept good records. The powrlok carrier in my trucks dana came from a 63 ( 1962 datestamp ) vintage truck although all the official sources say they never made a dana 60 that early .
No truck :-( Last edited by mikep; 03-16-2003 at 12:48 AM. |
03-16-2003, 02:35 AM | #8 |
A$$ deep into trucks
Hey guys,
I don't have any GM documentation to back it up, but from my experience, every FACTORY Big Block 1/2 ton in 1968 and 1969 that I have ever owned (3) or looked under(couple dozen) had the semi-floating 6-lug Dana 60 rear axle. Not to say it was required with the BB option, but I can't recall any 68-69 BB 1/2 tons with the standard 12-bolt. All BB 1/2 tons from 70 on (first of the wide axles) were 12-bolt. Anybody know more about the 6-lug Dana 60's??????? Mike
hardrock2 |
03-16-2003, 10:56 AM | #9 |
Coil 1/2 ton
1957 Cameo |
03-16-2003, 04:19 PM | #10 |
Parted 69 BB 1/2 ton truck.had a 12 bolt 3.0's Posi.Parted 68 GMC BB truck 3.5's Dana 60 Posi,67 Dana 44 3.5's thats some junk ive had in last months.
03-16-2003, 06:58 PM | #11 |
I probably don't see too many 6 lug semi floater dana 60's around here because we just dont see very many 1/2 tons period. Especially big block 1/2 tons. 90% of whats on the road is 3/4 ton long beds.
No truck :-( |
05-29-2003, 05:09 AM | #12 |
Do you still have the Dana 60 rear with coil springs?
Is it a full floater? Are the axles held on by bolts or studs with nuts? I am need of a 30 spline axle held on by stud/nuts and can't find one around here. Let me know thanks, Mike
Mike 1989 C1500 SWB Reg Cab 2003 Chevy Tahoe Z-71 70 Camaro RS/SS - 454 |
05-29-2003, 10:05 AM | #13 |
Chevynut - can you either post or email me a larger pic of your C20 with the camper (i.e., your avatar)? How many of the old trucks still have their campers on them???
Email greenaz@hotmail.com Paul
Paul 72 Cheyenne Super Custom Camper greenaz@hotmail.com |
05-29-2003, 11:25 AM | #14 |
"Trucks with Class"
...and I have two 1/2T GM Dana 60 rearends, 6-lug. One is a leaf and one is a COIL. Gear ratios are 3:54 & 3:73. The 4X4 guys love these because they bolt in a 1/2T and make it instantly twice as strong. I put one in a SWB 2WD behind a BB and had it converted to 5-lug. Simple install and strong. Springs & shocks bolted right up with no mods.
05-29-2003, 11:51 AM | #15 |
I am also curious as to why GM used 2 different axles...my GMC has a dana 60, 3.73 (originally 4.10 or 4.11) gears, and most other 3/4 tons seem to have the Eaton. Was this another Chevy/GMC difference or is just random which rear axle you got?
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
05-29-2003, 01:09 PM | #16 | |
Binder Rep
The Dana 60 FF in the 3/4 tons could be ordered, if you look through the options lists it was one of the axle ratings you could get. They did not call it a dana 60, just gave the weight ratings for each axle. |
05-29-2003, 02:11 PM | #17 |
I figured it was more common to find Danas under GMCs than Chevys, at least in the '66 and back trucks,(44s & 60s) as most,if not all of them stuck to the "GMC/leaf spring", "Chevy/Coil spring" set-up.
After that, seems you could special order leaf or coil under either one. My guess is GM was geared to mass- build 12-bolt stuff with the coil set-up, and GMC spec'd leaf set-ups to Dana, and that's what they built till '67, then they started sharing more stuff between the two lines of trucks. Until then, GMC was viewed as the "workhorse" of the two truck lines,and chevy was the "standard production", but evidently the market was calling for both trucks to be more versatile in their specs. so GM started to offer more options in common. Maybe an early move to "consolidate" the two truck lines?? After all, look at the '73-present Chevys/GMCs. Same truck, just different badging! JMO!
hardrock2 |
