Old 03-15-2003, 04:08 PM   #1
casey
casey's Avatar
wheel adaptors
Iwas wondering if anyone knows of a good place to get wheel adaptors for my 71 4x4, as you all know the rear diff is narrower than the front, and to give it a more even stance I'd like to bring my back rims out 1 1/8" on each side to square it up with the front. the way it sits now the rear wheels look to tucked in. Has anyone had any experience with this? Thanks
casey is offline   Reply With Quote
Old 03-15-2003, 08:30 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Why not swap a later 4WD rear end? The reason for the difference is the 71 and up disc brakes added width to the front track. The rear ends thru 73 were the same width, but not as wide as the disc brake fronts. I believe the 74 rear axles assemblies are wider than the earlier. If you already have a leaf spring rear, the swap should be easy. If not, you can do the conversion.
I don't know of any trustworthy spacers that are "affordable". There is at least one company that does make some high-dollar adapters/spacers, but I don't remember who it is.
Member Nr. 2770
Old 03-15-2003, 08:34 PM   #3
cdowns
cdowns's Avatar
if you have plans in the future of putting custom rims on the truck you can solve the problem with the proper offsets
Old 03-16-2003, 01:34 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And you may want to look into the legality of spacers. You also need to be warned of the (minimal) added stress it puts on your axles and bearings.
Old 03-16-2003, 02:51 AM   #5
low 84
low 84's Avatar
a couple things, don't get aluminum spacers. get steel ones. and expect to pay alot of money for good ones. i think just the two that i needed for my 17x9.5's on the front were around 120 bux. i will try to figure out who manufacutred them, i can't remember.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-16-2003, 03:32 AM   #6
casey
casey's Avatar
if you can remember low 84 could you pm me thanks, ChevRoLay I'd swap rear ends but mine was rebuild,cdowns I'd get custom rims but I got a nice set of rallys with 33's, and wider rims on the back mean you can rotate your tires, Longhornmail I thought about the added stress on the wheel bearings, but how would that be any differant than a wide off set rim, I don't plan on any off roading or pulling a trailer.
Old 03-16-2003, 01:05 PM   #7
Longhorn Man
Hmmmm, dam good point there.
Anyone smarter than me know why? I have just always heard that that one of the reasons they were illegal in Tx.
Old 03-16-2003, 02:07 PM   #8
mikep
Used to have a truck
mikep's Avatar
Its not the added stress on the wheel bearings thats the problem. Thats no different than a different offset and isnt a safety problem. The problem is that many spacers are just plates with holes in them that longer studs pass through. Its that type that is the problem as the longer unsuported stud can flex and fatigue and eventually break or shear off. Not good.
No truck :-(
mikep is offline   Reply With Quote
Old 03-16-2003, 04:12 PM   #9
casey
casey's Avatar
mikep the ones I'm looking for are the adaptors, there one solid peice, you bolt them to your studs and the adaptor has 6 more studs on it on the out side of the adaptor, to bolt your wheel, what do you think of those, low 84 says don't get aluminium,get steel makes sense to me.
Old 03-16-2003, 07:24 PM   #10
mikep
mikep's Avatar
I dont see any problem with the steel ones. You'll get a decrease in bearing life but BFD .
No truck :-(
Old 03-16-2003, 07:51 PM   #11
low 84
low 84's Avatar
thats exactly how mine are. my front 17x9.5s are 5x4.75 bolt pattern and the wrong offset, but the spacers are drilled to fit on the 5x5 bolt pattern, then they have their own studs in them for the 5x4.75 bolt patter n of the wheel. so they change the bolt pattern and push the wheels out some. i actauly bought them from a friend and he origainly ordered the spacers so i'll get in touch with him and see where they were made
'05 1500 Crew Cab
RIP
Old 03-16-2003, 09:26 PM   #12
casey
casey's Avatar
Thanks guys low 84 if you could find that out for me I'd appreciate it, or if anyone else knows of a source please reply
