03-15-2003, 05:08 PM | #1 |
rear gear ratio ?
Need the experts to confirm what rear gear ratio I have from a '71 2wd LWB 350 w/ 3 speed column shift. Pulled the cover off the 12 bolt rear end and found the following numbers stamped on the ring gear:
3817779 14 43 GM 2-71 along with some other numbers that did not get a good stamping. Can not be read. By doing the math (divide 43 by 14 = 3.0714285 or 3.07 gear ratio. I also counted the ring teeth (43) and pinion teeth (14) to confirm what I thought the 14 & 43 numbers referred to. ( I am not much for rear axle knowledgez) So the gear is 3.07 or is it 3.08 ? After I know for sure what I have, the rear end will be on the sale block as it won't do much good for my 71 4x4. Just want to know for sure what I am selling before I offer it. Thanks to all who reply.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
03-15-2003, 05:38 PM | #2 |
Fabricate till you "puke"
Yup, you found the right #....its a 3.07 gear.....
