02-12-2011, 04:53 PM | #1 |
power steering question.
finally warm and it is not snowing so i can work on the truck.lol.my question is i got the power steering plate from captionfab and a steering box from a1986 truck with pitman arm should i also change the idler arm to match the pitman arm trying to get all parts before i start.thanks for any and all help.tim reagan
02-12-2011, 05:09 PM | #2 |
But Found Her 25yrs Later!
Re: power steering question.
I kept the original idler on mine.
If the condition of yours is good, I wouldn't bother. http://67-72chevytrucks.com/vboard/s...d.php?t=438509 Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 02-12-2011 at 05:12 PM. |
04-30-2011, 12:00 PM | #3 |
Rollin' Old Skool
so, i am getting ready to add power steering on my '66...my 5-lug front disc conversion uses parts from a '72 (control arms/spindles/etc)....i kept the original '66 centerlink...when doing the conversion this way, you use '66 outer tie rods at the inner location, & the outer tie rods are '72...this is connected with a POL conversion sleeve....i'm upgrading/replacing everything with Moog parts....to keep confusion to a minimum, i plan to use a '72 power steering gear box, pump, brackets, etc...my question is, do i need a pitman arm for a '72, or would i need one for a '66? or does it even matter?
04-30-2011, 08:54 PM | #4 |
iused the same so as it was a match set same year.hope this helps.tim reagan
04-30-2011, 10:33 PM | #5 |
Rollin' Old Skool
that was my plan, to use a '72 to match the gear box...just wasn't sure if there are any differences between the two....with keeping the '66 centerlink, i'm using a '66 idler arm...this kept me from having to drill holes & relocate a '72 idler if I had used a '72 centerlink
05-01-2011, 03:21 PM | #6 |
Double 6's
I just did the swap, and used the whole steering assembly from my '82.
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
