Old 02-12-2011, 07:33 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Has anyone here converted a cab from low to high hump ?(UPDATED 2-17 with pics)
This topic is an FAQ- "73-87 Converting a cab from low to high hump"
I have an 85 model low hump cab and have a line on a 78 model SM465 4 speed transmission and the bolt in high hump floor from the same truck. Thing is, I don't have a way to put hands on it right now and see for sure.
My question is, will the high hump cover drop into place if I cut the hole and make arrangements for the hold down bolts ?
This may seem a stupid question, but I know from first hand experience that 60-66 trucks have a different firewall and require a good bit of modding to make it work when swapping low to high. I further know that 67-72 trucks, it's just cut the hole and bolt the hump in place. But, I've never done this on a 73-87 and my current cab is finished to near show quality. If it requires more than cutting a hole and some weld nuts I won't mess with it.
Thank you,
Kevin
Old 02-12-2011, 09:04 PM   #2
joe b
Re: Has anyone here actually converted a cab from low to high hump ?
I put a 4 speed in my 87c/10 . the floor is not like the 67-72 there is no outline like 67-72 has
joe b is offline   Reply With Quote
Old 02-12-2011, 09:12 PM   #3
Tx Firefighter
Did you bolt in a high hump to your previously low hump cab when you did the swap ?
Old 02-13-2011, 11:15 AM   #4
78cheyenne292
wow this post couldnt have came at a better time i was just looking for a 4 speed manual and i was wondering what it would take to switch my hump. if someones got pics please post!!
78cheyenne292 is offline   Reply With Quote
Old 02-13-2011, 11:15 PM   #5
eke82
yes it should but is it also 4wd or not you might have to cut part of the old cab out where it is under the seat to clear the transfer case it sets up about 2 inches higher the the 2wd cab
eke82 is offline   Reply With Quote
Old 02-14-2011, 12:33 AM   #6
f.monroe
f.monroe's Avatar
This may be what you are looking for . I remembered this thread and looked it up .
Frank
http://67-72chevytrucks.com/vboard/s...=383629&page=2
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-17-2011, 02:29 PM   #7
Tx Firefighter
Well the answers were kind of varied so I decided to just dive off into the project.
This is an 85 model cab and a 78 model high hump. Both trucks were 2wd. Best I can tell by looking at the junkyards, most newer model cabs like mine (85 model) had a built in high hump or a built in low hump. I could not find a later model cab with a bolt in hump around here. So, I had to use the 78 model bolt in hump. The two floor pans are quite different.
I had to reshape the edges with a hammer against a straight edge to get the contour proper to fit the floor. Figure about 10 minutes of bumping the metal, test fit, and repeat. The floors are similar but definitely not the same. The edges on the sides of the hump had to be dressed downward to make it hug the floor properly.
Lay the tunnel into place and mark the perimeter, then remove and mark a second line about an inch inside of the perimeter mark. That's your cut line.
Hillbilly Plasma Cutter...
Resulting hole...
Now bolt the tunnel in place with 5/16 bolts and nuts with washers on the underside...
Roll underneath and weld the nuts and washer combos to the cab floor.
All in all, pretty easy. Figure an hour and a half to do the work.
Old 02-17-2011, 03:10 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Thia would make a good FAQ thread.
Thanks for posting.
Keith
Convert to disc brakes.
Old 02-17-2011, 04:49 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for posting.
I agree. Lets get it done..
Old 02-17-2011, 06:01 PM   #10
4x4toy
I have a bolt in hi hump from a 4x4 blazer, 1984 I think. Does not fit my 85 C20 very well. The rear of the bolt in floor is too high in the rear. Hope this info is of use to someone. I will mock it and try to take a picture this weekend. Now I need to find a 2wd hi hump floor.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 02-17-2011, 07:00 PM   #11
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
your line is alot cleaner than mine. lol
I converted an automatic to a Granny 3..Why? Because the truck was cheap and the motor and trans were free.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 02-18-2011, 12:46 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for the write up Kevin. Subscribing so I don't forget to add it to the FAQ's.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-18-2011, 02:20 AM   #13
lolife99
lolife99's Avatar
Isn't the 4x4 floor area directly behind the hump taller to clear the transfer case?
So would that mean there are two different high humps?
2wd and 4wd?
Keith
Old 02-18-2011, 03:32 AM   #14
y5mgisi
Second Chance Program
y5mgisi's Avatar
Thats kinda what im thinking. I never knew there was such a thing as a 2wd high hump!
y5mgisi is offline   Reply With Quote
Old 02-18-2011, 08:57 PM   #15
N2TRUX
Happy to be here
N2TRUX's Avatar
Articles-
"Refining Sierra"
Old 02-18-2011, 09:39 PM   #16
lolife99
lolife99's Avatar
2wd 4-speed manual trucks, I assume.
Keith
Old 02-18-2011, 09:45 PM   #17
Tx Firefighter
Yes, 2wd floor shift trucks. The 4wd high hump has a larger rear raised area for the transfer case clearance up under the front of the seat.
In my local junkyards, all of the early 4 speed 2wd trucks had bolt in humps, but the later, 80s era, trucks had a built in large hump that is not removable without cutting. I did this swap to allow a 4 speed transmission underneath a low hump (factory auto trans) cab.
