Old 02-13-2011, 12:04 AM   #1
smilts60
How Low Can I Go?
I know they can go as low as wanted. But does anyone know how I can go and still keep my wooden bed intact? its a LWB stepside if that matters for this question.
smilts60 is offline   Reply With Quote
Old 02-13-2011, 01:02 AM   #2
chevykid65
chevykid65's Avatar
Re: How Low Can I Go?
c notch. coils springs or coilovers? 4 link or stock trailing arms? it all depends on your ability or your wallet. you can even raise the bedfloor. it just depends on how detailed you want to go. in my 65 long fleet im sitting with 15s tucked to the top of the rim by simply changing out the springs. im thinking later plans are to do a mild step notch and either raise the bedfloor or even no floor at all. anything you can imagine you can build. just do your research and make sure your ready to take it on. theres alot of really knowlegable people on this board and can help point you in the right direction
chevykid65 is offline   Reply With Quote
Old 02-13-2011, 03:57 AM   #3
smilts60
Right thank you. Yes my goal is to drop it way low, or as low as possible without having to touch the bed at all. I have been looking and searching but I'm still confused as to how low that is.
Old 02-13-2011, 04:19 AM   #4
Miller92
Miller92's Avatar
Hey Smilts, I had a similar question in another thread I had started, maybe this will help ya out.
http://67-72chevytrucks.com/vboard/s...d.php?t=439503
Miller92 is offline   Reply With Quote
Old 02-13-2011, 07:54 PM   #5
BarnFind
I have tried every possible static drop you can come up with. The best, in my opinion, is CPP 2 1/2 drop spindles with 3 in coils and drop shocks. In the rear, a CPP c-notch, 5 in drop coils, 2in blocks, and drop shocks. This is low, rides real nice, and you can still get in and out of driveways. Here is a picture of this drop. Sean
BarnFind is offline   Reply With Quote
Old 02-13-2011, 10:00 PM   #6
TudorJeff
Barn Find your truck sets perfect. What size tires are you running?
TudorJeff is offline   Reply With Quote
Old 02-13-2011, 10:34 PM   #7
BarnFind
Fronts 235-60-15 on a 6in GM wheel Rear 255-60-15 on a 8in GM wheel
