02-13-2011, 09:54 AM | #1 |
cab mount bolts
I twisted the rear cab mount bolt in half ,now what do I do to repair that
02-13-2011, 10:18 AM | #2 |
Re: cab mount bolts
Are you removing the cab? Or just installing new cab bushings?
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
02-13-2011, 10:24 AM | #3 |
Re: cab mount bolts
I had both of my rear cab bolts twist off. I removed the tank and cut off the straps that lock the nut into place then you can pull the bolt out the top.
02-13-2011, 11:51 AM | #4 |
Re: cab mount bolts
I was only replacing bushings. thanks for the info , I guess I will remove tank now so I can get to bolts
