Door Seals (HELP)
I just installed new door seals and now you have to slam the passeger door to get it closed and the driver side will not close all the way. Anyone ever experienced this? Any suggestions? Thanks for you time
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR" ![]() |
Re: Door Seals (HELP)
when i had that problem i used a heat gun to very carefully heat the seals and then close the door to form the gaskets
TOO MUCH HEAT WILL MELT THEM
most company's will tell you put them on slam the doors and let them sit in the sun for a couple days if that don't work get you some soft seal door seals, some of the cheaper seals are just that way. Ihad the same problem with also.
Where do you get soft seal door seals?
softseal.com go to there website and read how they say to install them . hope this has helped
The Older Generation
There is some good info in this thread... http://67-72chevytrucks.com/vboard/s...d.php?t=439323 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-13-2011 at 12:46 PM. |
