Old 02-13-2011, 09:18 PM   #1
neversatisfyd
neversatisfyd's Avatar
Needing more front tire clearance
I have a 72 c-10 that i would like to narrow up the front end to be able to drive it at a lower stance. The truck lays all the way out but i have raise it higher than i like to be able to drive it without getting into the fenders. To begin with the truck has been z'd 3" , drop spindles, art lower strong arms, and factory upper a-arms, on air bags. I am running the boss 338 20x8.5. Any suggestions without hacking up the suspension anymore or spending major bucks? ive seen on portebuilt's site that they can make their control arms narrower than stock and have also seen a few other sites with narrowed control arms. is that my best option?
7 DEUCE
"PRAISE THE LOWERED"
neversatisfyd is offline   Reply With Quote
Old 02-13-2011, 09:55 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Needing more front tire clearance
Either narrower control arms, or CPP spindles.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-13-2011, 09:59 PM   #3
neversatisfyd
do you have any suggestions of brands of narrowed control arms? anybodys any better than the others?
7 DEUCE
Old 02-13-2011, 10:35 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
...or more backspacing
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 02-13-2011, 10:45 PM   #5
neversatisfyd
That is a thought also, but i think that its easier to buy suspension parts than it is to find another set of wheels! Im not sure but i think the boss 338 wheels are a standard backspace? Plus my wife says i buy too many wheels as it is! Ha!
7 DEUCE
Old 02-13-2011, 11:14 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
I would say talk to Nate at Porterbuilt. My guess is he will build what you need.
Articles-
"Refining Sierra"
Old 02-13-2011, 11:59 PM   #7
neversatisfyd
thanks, i will try to call him tomorrow if i get a chance. just looking for any other ideas but i thought those were my only options.
7 DEUCE
Old 02-14-2011, 12:47 AM   #8
cajundragger
shortening the lower arm would give you what you want, but then your upper bj will probably(like 99.9% sure) bind, so you'll need to cut/weld there to make them work or buy something like ART uppers.
also when you lift the truck truck it will positive camber pretty good.
I had this same issue on my truck. I just went and added an 1 inch more backspace on the front wheels. now when its laid out it looks like it doesn't have any wheels on it they are so far tucked in, but I ride around 1" or so and can turn so its all good.
cajundragger is offline   Reply With Quote
front end, lowering, suspension
