Old 02-13-2011, 09:51 PM   #1
rustycarr
engine decode 230 or 250?
just found out my engine could be a 230 or 250 so i need some help. its a 65 c10 with a six cylinder,3 on tree. the stamping on engine is 3877178 and behind the distributor is F0303TF.
Also near back of block is CON2 C25
also i have the head off and can see the pistons, they have little D shapes on them. thanks.
rustycarr is offline   Reply With Quote
Old 02-13-2011, 10:56 PM   #2
Heater63
Heater63's Avatar
Re: engine decode 230 or 250?
If you've got the head off, measure the stroke. 3.25 is the 230 and 3.5 is the 250 if I am correct.
the casting # wont help much, as that # and most others, were used on both engines. Thats the same casting as my '63 230, and was used all the way through 1978.
The Con2 means conveyor 2 at the plant.
The stamping on the distributor pad should tell you final build info, you might check on Inliners.org to see if someone has the decode info
The 230 used a "flat top" piston with valve relief eyelets, the 250 and 292 had the D shaped recessed you describe, so it yours should be a 250.
Your fuel pump is forward of the passenger side engine mount and the engine mounts are symmetrical/equal, and not offset right? If your mounts are staggered it is a 292
Regardless, the 230/250 use common parts and should be considered almost the same.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 02-13-2011, 11:05 PM   #3
rustycarr
Can't check stroke, engine is seized.
Mounts symmetrical,
Old 02-13-2011, 11:38 PM   #4
Heater63
Heater63's Avatar
Its probably a 250 based on the pistons. Since it sounds like a major rebuild is in order, even if it is a 230, you can get a reman'd 250 crank and make it a 250. I think the only difference between 230/250 is crank and pistons.
Lots of info to improve its performance at Inliners.org
The bible on these motors is Leo Santucci's. get a copy if you want to plan any mods or hottrodding.
292 + TKO500
Old 02-14-2011, 07:06 AM   #5
rustycarr
here is a pic of the piston:
Old 02-15-2011, 03:27 AM   #6
Heater63
Heater63's Avatar
Thats 230.
See my first post. Flat top with eyelet valve reliefs
292 + TKO500
Old 02-15-2011, 03:30 AM   #7
Heater63
Heater63's Avatar
Originally Posted by Heater63 View Post
Thats 230.
250 and 292 pistons look like this:
292 + TKO500
Old 02-15-2011, 10:33 AM   #8
rustycarr
Thanks, the small "D" looking designs on my pistons made
me think it was a 250. No matter, just glad to know what
kit I need
Old 02-15-2011, 11:26 AM   #9
Heater63
Heater63's Avatar
Rusty, are you talking about a gasket kit or engine kit (bearings, pistons, etc?)
the 230/250 gasket kit should be the same.
If your talking about an engine kit, you need to buy that with your machine shop after they have processed the block. You will probably end up +30 or +60 on your bore size and the crank may need turning and undersized bearings.
292 + TKO500
Old 02-15-2011, 05:04 PM   #10
rustycarr
