Old 02-13-2011, 10:09 PM   #1
lt704
LMC headliners
Hi guy's,, I have been doing my interior over. P.O had material on inside of roof. Cleaned it up and want to put a headliner in. There are no holes on the inside of the roof. I was looking at the vynal covers headliner from LMC. Where there was not a headliner before can i use the one from LMC?. How does it fasten to the roof?. Do i need buy the chrome piece to?. Thanks for the help. Russ
lt704 is offline   Reply With Quote
Old 02-14-2011, 05:47 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: LMC headliners
You can cut holes to use the plastic chrome trim, but it is a TOTAL pain to do, and not worth it IMO.
Just glue the headliner to the metal. I used liquid nails myself. You'll need to glue it either route you go.
Old 02-14-2011, 05:55 PM   #3
lt704
Re: LMC headliners
Hi Longhorn man, thanks for the feedback. I will do what you suggest and put just the headliner up with liquid nails. I was also thinking of putting up the abs plastic headliner with the speakers in it, but i think the stock looking headliner will look better. Thanks again...Russ
Old 02-14-2011, 06:10 PM   #4
Jonce
Jonce's Avatar
Re: LMC headliners
I used one of their headliners in my '71 GMC. I went to the Napa auto parts store and picked up some 3M Adhesive for headliners. 3M makes a great product in my opinion.
When I installed it, I removed my bench seat. Then I cut a piece of plywood the same shape as the headliner. Once that was cut, I cut 2 or 3 pieces of 2x4's so it would hold the headliner and the plywood template in place by wedging the 2x4 between the ceiling and floor. It's been on there for 4 yrs and still looks perfect!
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 02-14-2011, 06:16 PM   #5
norml495
Re: LMC headliners
Dude, I put the same headliner in last month(mine came from the truck shop-in orange,ca.), and I used 3M super duty trim adhesive #08090 --- that's what the crap is made for!! It's about $16.00 at the auto paint store.
good luck
norml495 is offline   Reply With Quote
Old 02-14-2011, 08:26 PM   #6
Longhorn Man
Re: LMC headliners
While I've never used that specific 3M product, I have used plenty of that type of adhesive and was always let down (no pun intended) a few years after the fact. Liquid nails will hold forever.
I did it very much like Jonce described, except U left the seat in and let the springs in the seat push the 2x4s and plywood up against the ceiling
Old 02-14-2011, 09:06 PM   #7
lt704
Re: LMC headliners
thanks for all the tips guys. I really like the idea of the plywood and 2x4's, what a great way to install...thanks...Russ
