Old 03-15-2003, 08:53 PM   #1
Dads72
Vacuum Advance ?
350 out of a 72 Chevelle.
HEI.
What do I tell the parts guy if I need a new vacuum advance?
Dads72 is offline   Reply With Quote
Old 03-15-2003, 10:04 PM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Depends on what you want to do. You can simply get a vacuum module for the distributor. If you want about 20% increase in highway milage, it doesn't take a lot more. That's when you get an advance kit, which has new weights, springs, and an adjustable modulator. You will also need a timing tape, which goes around your harmonic balancer, and allows you to read up to about 45 degrees advance. There was a good article in Chevy Hi Performance magazine about 3 months ago on this.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-16-2003, 01:30 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Just tell them you have a 75 1/2 ton, or camaro or something like that.
Although, i'll second the adjustable one. I like mine and it helps on dialing it in.
