02-14-2011, 01:57 AM | #1 |
72 1/2 ton 350 trans smallblock 2wd what shfit linkage do i need?
i need a shift linkage for a 2wd 72 1/2 ton 350 tranny in the forward mounting holes for the engine does anyone have any pics? i have a these brackets but i dotnt have the holes for these on my frame rail
02-14-2011, 06:40 AM | #2 |
Re: 72 1/2 ton 350 trans smallblock 2wd what shfit linkage do i need?
Here is a picture of the 70-72 linkage.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
02-14-2011, 09:06 PM | #3 |
okay i have the bracket that goes to the frame i need the bracket thats on the tranny and the one that goes on the frame mount..
02-14-2011, 09:50 PM | #4 |
I'm positive you already have the holes for the frame side bracket. I converted my 68 over and had no probs at all if you have all the parts. You would be wise to contact someone in the parts for sale area and just get the whole thing.
07-02-2011, 10:51 PM | #5 |
what other kind are there i was searching this on google and it caame up with another kind that i have almost all the parts for
07-03-2011, 12:25 AM | #6 |
PROJECT 7DEUCE
I dont remember seeing those parts on mine I used a lokar bracket and rod on my blazer???
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-03-2011, 12:29 AM | #7 |
hmm im on the cheap so i cant get a lokar or anything so.... im screwed huh?
07-03-2011, 01:28 AM | #8 |
PROJECT 7DEUCE
If you figure out what brackets you are missing let me know ill take a look in th parts boxes sunday and see what i have left over..
07-03-2011, 02:21 AM | #9 |
i am missing the bracket that goes on the tranny shown in the pic above and the arm that connects to that bracket and the one on the frame other then that i have the frame bracket and the rod
07-03-2011, 08:32 AM | #10 |
i just pulled a TH 350 from my burb to make room for a SM465. i gave the trans brackett away with the trans, but i have the frame brackett, and the 'bell crank' part along with a spring that goes in there. it's yours if you need it.
07-03-2011, 02:23 PM | #11 |
you have the part that bolts to the tranny in the pic shown above?
